inter-vlan routing on CIsco 881 router ?
pfrancis3
Hello, I have configured my 881 to perform inter-VLAN routing i.e. I am using ports 0-2 as tagged switch ports (with PC's plugged in and addressed on their relevant subnets) and port 3 as a trunk feeding in to port 4 as a router on stick configuration.
For some reason I am unable to ping between subnets. It seems the trunk is failing ?
Could someone please take a look and help me out. It must be something basic. This is driving me crazy.
p.s. I have entered 'switchport trunk encapsulation dot1q' on port 3 (the trunk) however it is not showing up.
Thank you kindly for any help.
Building configuration...
Current configuration : 1564 bytes
! Last configuration change at 22:45:55 UTC Wed Apr 29 2015
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip flow-cache timeout active 1
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FGL171824DY
interface FastEthernet0
 switchport access vlan 10
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 switchport access vlan 2
 no ip address
interface FastEthernet3
 switchport trunk native vlan 15
 switchport mode trunk
 no ip address
 spanning-tree portfast
interface FastEthernet4
 no ip address
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
interface FastEthernet4.1
 encapsulation dot1Q 15 native
 ip address 192.168.15.1 255.255.255.0
interface FastEthernet4.2
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
interface FastEthernet4.10
 encapsulation dot1Q 10
 ip address XXX.XXX.XXX.XXX 255.255.255.252  <== altered to block public ip address details
interface Vlan1
ip default-gateway XXX.XXX.XXX.XXX <== altered to block public ip address details
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source FastEthernet4
ip flow-export version 5 origin-as
ip flow-export destination 192.168.247.232 9996
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX <== altered to block public ip address details
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
mfurnival
Level 4
Level 4
Are you able to provide a diagram please? Having trouble understanding what you are trying to do.
