Inter VLAN routing on N5548P without L3 Daughter Cards
davidespeso
I have a DC topology based on 2 layers, access and aggregation, based on 2 pairs of N5548Ps, both without L3 Daugher Cards. My intent is to use the aggregation N5K pair as L3 inter VLAN layer, so I configured all the VLAN default GWs there. The 2 layers are interconnected via vPC, in a double-sided vPC topology for some N2Ks and some vSwitches.
The point is that, despite connecitivity is working fairly ok, for some applications, like file transfer via either FTP or HTTP, between hosts in different VLANs, the performance is too poor. The file transfer starts ok, but after a while it becomes lower and lower. ICMP is working, but I can see some strange random behaviour, like having some packets taking more that 20 ms (sometimes 40 or more), whilst average is 2 ms.
I read through some articles saying that until you don´t have the L3 license (the one coming with L3 Daughter Cards) you can expect some weird behaviour on L3 level. Is that true?. What can I do apart of purchasing L3 Daughter Cards?. Can I enable L3 Basic license at the moment (I don´t need dynamic routing for now).
Here some excerpts of what I´m saying:
PING results:
10000 packets transmitted, 10000 packets received, 0.00% packet loss
round-trip min/avg/max = 0.809/2.496/57.559 ms
System version: 5.0(3)N2(1)
License and features on the N5Ks:
switch# sho license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
LAN_BASE_SERVICES_PKG         No    -   Unused             -
LAN_ENTERPRISE_SERVICES_PKG   No    -   Unused             -
switch#
switch# sho feature
Feature Name          Instance  State
Flexlink              1         disabled
adapter-fex           1         disabled
bgp                   1         disabled
dhcp                  1         disabled
eigrp                 1         disabled
eigrp                 2         disabled
eigrp                 3         disabled
eigrp                 4         disabled
fcoe                  1         disabled
fcoe-npv              1         disabled
fex                   1         enabled
hsrp_engine           1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
ldap                  1         disabled
lldp                  1         enabled
msdp                  1         disabled
ospf                  1         disabled
ospf                  2         disabled
ospf                  3         disabled
ospf                  4         disabled
pim                   1         disabled
poe                   1         disabled
private-vlan          1         disabled
privilege             1         disabled
rip                   1         disabled
rip                   2         disabled
rip                   3         disabled
rip                   4         disabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         enabled
udld                  1         disabled
vem                   1         disabled
vpc                   1         enabled
vrrp                  1         disabled
vtp                   1         disabled
switch#
and modules installed:
switch# sho module
Mod Ports  Module-Type                      Model                  Status
1    32     O2 32X10GE/Modular Supervisor    N5K-C5548P-SUP         active *
3    0      O2 Non L3 Daughter Card          N55-DL2                ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    5.0(3)N2(1)     1.0     --
3    5.0(3)N2(1)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    547f.ee2d.e968 to 547f.ee2d.e987         FOC15370EGJ
3    0000.0000.0000 to 0000.0000.000f         FOC153858PB
switch#
Thanks in advance
6 Replies 6
Reza Sharifi
If you need to do inter-vlan routing with SVI (layer-3 functions) on your switches, you need daughter cards.
The 5Ks without daughter cards are just layer-2.
Leo Laohoo
You need a Layer 3 daughter card and activate the complimentary layer 3 license that comes with it.
Otherwise, you'll need another appliance to do the layer 3 for you, like another layer 3 switch or a router.
Hi, thanks both of you for your swift answer.
The point is that there is connectivity inter-vlan but performance is not as good as desired. Looking at your answers it looks like a matter of no grey room for it, so if not having the cards, then you cannot do any inter-vlan communication, but the fact is that packets go across different VLANs, but with some misbehaviour.
When reading Cisco Support pages, it seems it is possible to do it with the basic license LAN_BASE_SERVICES_PKG. It´s also very weird that in on of the access switches I do have that license enabled, whilst being pure L2 switch not having L3 Daughter card:
switch# sho licens
license_SSI1543064Q_17.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_BASE_SERVICES_PKG cisco 1.0 permanent uncounted \
        VENDOR_STRING=MDS HOSTID=VDH=SSI1543064Q \
        NOTICE=201201301947550001N5K-C
5548P-BUNSSI1543064Q \
        SIGN=887B7F66FDC2
INCREMENT LAN_ENTERPRISE_SERVICES_PKG cisco 1.0 permanent uncounted \
        NOTICE=201201301947550002N5K-C
        SIGN=2D07F1B64BD0
switch# sho licens usage
                                 Count
LAN_BASE_SERVICES_PKG         Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
switch#
Thanks!
Hello;
Did you figure out what was the problem? all documents says it is okay to configure it without any need for additional license or the L3 DC...any updates you have?
The Nexus 5K is originally a Layer 2 appliance.  So aside from a Layer 3 daughter card or line card, yuo need something to do the Layer 3 functions externally like a Layer 3 switch or a router.
If in doubt, you can always raise a Cisco TAC Case.
arikawahyono
