Inter Vlan Routing with WS-C3560G
Hello Team,
Can I do the inter Vlan routing with  WS-C3560G-24TS-S and  15.0(2)SE11 ,SW Image C3560-IPBASEK9-M .
Asanka
Thanks for the valuable advice, It helped much.
Joseph W. Doherty
Yes, although your IGP options are limited with the IPBase feature set.  (I recall you only have static and RIP; plus you don't need either if all the VLAN SVIs are on the 3560, just need to insure "ip routing" is configured.)
Glad that helped.
BTW, besides SVIs, you can also route directly on the 3560 using "routed" interfaces (non switchport).  I.e. they and/or SVIs might be used.
Static routing statements, or an IGP, like RIP, are only needed if the destination network isn't directly connected.
