Inter VLAN routing
malachi78
Community Member
I am new to CISCO. Please guide me how to do inter vLAN routing. Please tell me along with command
shane.kearney
Level 2
Level 2
ok here is the low down on intervlan routing.
you have 2 VLANs lets call then sales and IT they are both connected to the same router lets say E0(Sales) and E1 (IT)
the ip on sales is 192.168.1.1 and on IT is 192.168.2.2, it goes like this
Vlan database
vlan 10
vlan 10 name Sales
vlan 20
valn 20 name IT
exit
config t
int FA0/1
switchport access vlan 10
int FA0/2
switchport access vlan 20
move to the router now and issue these cmds
config t
int fa0/0.1
encapsulation dot1Q 10
no shut
Interface Fa0/0.2
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
no shut
now back to the switch and the interface that connects the switch to the router, lets call it Fa0/3 issue this command
Int FA0/3
switchport mode Trunk
and now it works!!
ranjan4453
Community Member
Hello Malachi,
Pls go through the below url and you wil get a clear understanding with commands also.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Tks
Mrp
matthewt1501
Community Member
Thats an open ended question my friend.
Do you a have a Router, or MSFC Card?
As you need at least some routing capabilities to communicate between VLANS....
There are a few topologies you can create... the best thing is to tell us what you have, and how it's set-up.
Failing that search for Inter-VLAN Routing on this site, and there are more that enough resources here!
Cheers.
Matt
