Inter vlan routing
kolawole1
Level 5
Level 5
Is it possible to configure intervlan routing on a cisco 871 router ?
2 Accepted Solutions
John Blakley
It depends. I think there may be a maximum of 2 vlans in the standard license. You can check like this (this is from memory, and I'm getting older :-):
Router# vlan-switch
Router(vlans)# vlan 2
Router(vlans)# vlan 3
At this point you would get an error. You can also possibly do a sh ver to find out how many vlans you're licensed for.
After creating your vlans, you create your interfaces:
fa4: (public)
ip address 5.5.5.5 255.255.255.0
fa0: (private)
no ip address
no shut
fa0.10
encaps dot1q 10
ip address 10.10.1.1 255.255.255.0
fa0.20
encaps dot1q 20
ip address 10.20.1.1 255.255.255.0
If you're going to nat, then you need to insert your ip nat statements inbound (ip nat in) on every subinterface that you want to nat.
--John
HTH, John *** Please rate all useful posts ***
Should be. After you create your vlans in the database, you can create your interface vlan1, vlan2, etc. Then assign the addresses like you want, and assign each switchport to whatever vlan you want.
--John
John Blakley
Router# vlan-switch
fa4: (public)
fa0: (private)
no ip address
no shut
fa0.10
encaps dot1q 10
fa0.20
encaps dot1q 20
--John
Thanks.I was making confusion.
I want to make each switch port of the 871 router as a routed port (like when configuring an hwic 4ESW as a router port) by typing:
int vlan 1
ip address 172.16.1.250 255.255.255.0
no shut
int vlan 2
ip address 192.168.1.254 255.255.255.0
no shut
fa0:
switchport mode access
switchport access vlan 1
fa1:
switchport access vlan 2
So i could ping the private interface ip address.Is it possible ?
--John
Thank you.
My issue is resolved.
