Inter-vlan Routing
rodrigo2673
Community Member
I hope you can help me. I am not sure what I'm missing in this configuration. I've 2 PC's in 100.0.0.0/24 Vlan 100 on a 3550 switch. I've created an SVI 10 connected to my sky router (192.168.0.0/24)
Here is the info:
Top#sh ip int bri | exc una
Interface              IP-Address      OK? Method Status                Protocol
Vlan10                 192.168.0.100   YES manual up                    up
Vlan100                100.0.0.10      YES manual up                    up
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
     100.0.0.0/24 is subnetted, 1 subnets
C       100.0.0.0 is directly connected, Vlan100
C    192.168.0.0/24 is directly connected, Vlan10
S*   0.0.0.0/0 [1/0] via 192.168.0.1
Top#ping google.com
Sending 5, 100-byte ICMP Echos to 173.194.41.142, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/41/44 ms
Top#
Top#ping 100.0.0.1
Sending 5, 100-byte ICMP Echos to 100.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
Top#ping 100.0.0.2
Sending 5, 100-byte ICMP Echos to 100.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Top#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Top#
Top#sh ip cef
Prefix               Next Hop             Interface
0.0.0.0/0            192.168.0.1          Vlan10
0.0.0.0/32           receive
100.0.0.0/24         attached             Vlan100
100.0.0.0/32         receive              Vlan100
100.0.0.1/32         attached             Vlan100
100.0.0.2/32         attached             Vlan100
100.0.0.10/32        receive              Vlan100
100.0.0.255/32       receive              Vlan100
192.168.0.0/24       attached             Vlan10
192.168.0.0/32       receive              Vlan10
192.168.0.1/32       attached             Vlan10
192.168.0.2/32       attached             Vlan10
192.168.0.5/32       attached             Vlan10
192.168.0.12/32      attached             Vlan10
192.168.0.100/32     receive              Vlan10
192.168.0.255/32     receive              Vlan10
224.0.0.0/4          drop
224.0.0.0/24         receive
240.0.0.0/4          drop
255.255.255.255/32   receive
From my client PC's in vl 100 (100.0.0.1/24)
C:\>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Ethernet adapter Lan:
        Connection-specific DNS Suffix  . :
        IP Address. . . . . . . . . . . . : 100.0.0.1
        Subnet Mask . . . . . . . . . . . : 255.255.255
        Default Gateway . . . . . . . . . : 100.0.0.10
C:\>ping 100.0.0.10
Pinging 100.0.0.10 with 32 bytes of data:
Reply from 100.0.0.10: bytes=32 time=2ms TTL=255
thank you in advance,
Rod
2 Accepted Solutions
Does the sky router have a route back to 100.0.0.0/24 network, if it hasn't then it won't work.
Alain
Hi Rodrigo,
Please verify "ping 192.168.0.1 source vlan 100" from you switch.
If ping fails, verify the routing table entries in your sky router - "show ip route 100.0.0.0"
If it does not have a route, add a static route "ip route 100.0.0.0 255.255.255.0 192.168.0.100"
Again verify "ping 192.168.0.1 source vlan 100" from you switch.
Rajmohan R
7 Replies 7
rodrigo2673
Community Member
sorry forgot to add sh vl bri
VLAN Name                             Status    Ports
1    default                          active    Fa0/4, Fa0/5, Fa0/6, Fa0/7
                                                Fa0/8, Fa0/9, Fa0/10, Fa0/11
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/15
                                                Fa0/16, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/24
                                                Gi0/1, Gi0/2
10   Ferrari                          active    Fa0/2
20   Lamborghini                      active
100  VLAN0100                         active    Fa0/3, Fa0/23
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
Vlan100 is up, line protocol is up
  Internet address is 100.0.0.10/24
  Broadcast address is 255.255.255.255
  Address determined by setup command
Vlan10 is up, line protocol is up
  Internet address is 192.168.0.100/24
Alain
rizwanr74
Level 11
Level 11
Hi Rodrigo,
Please try to extended ping "google.com" by sourcing from svi 100
ping
Protocol [ip]: 4.2.2.2
Source address or interface: 100.0.0.10
If you cannot ping, then there is nat missing for network segment 100.0.0.0/24.
You should able to ping 192.168.0.100 from you PC though.
thanks
Rizwan Rafeek.
Hi Rodrigo,
Rajmohan R
gajularamu
Community Member
Hi Rodrigo,
I guess what Cadet siad is right, did you check on your sky router that it is having a route back to vlan100?
if not,u can give static route for vlan 100 network on router facing to switch vlan 10.
the other case, you can make router acting like host by disbling the route lookup and giving the default-gateway to vlan 10.(if you  want your router to act like host just like the othetr PC's.
Thanks & regards
Ramu Gajula
rodrigo2673
Community Member
Thank you All for all your replies.
Unfortunately there is no option in the Sky router to add a static route back to my vlan(s)
Best regards,
Rod
ok in this case is there any option to run a routing protocol like RIPv2  on the Sky router?
if so then you can advertise these vlan to the router  with RIPv2 on the switch.
The last problem is that maybe the router won't accept to NAT the vlans and in this case you won't be able to get to the Internet because you can't NAT on the L3 switch and your vlans will only be able to talk to the router but not further.
Alain
