Inter vlan routing
mahimakundu1
Community Member
Current Scenario:- Firewall is connected to a switch and that switch is connected to other switches in piggy backing scenario, there are no only 2 vlan, native and vlan20 with 30 hosts, all other 250 hosts are in native plan.  All hosts have firewall as their default gateway, and internal routing is also being done by firewall.
we want to create more vlan's and internal routing to be done by layer3 switch, in that scenario what will be the config of switch interface connected to firewall(will i have to define a default route) and what would be the default gateway for hosts?
Andre Neethling
Level 9
Level 9
Depending on the firewall model............ I would have a routed switch port with a /30 network between the firewall and layer 3 switch. Each vlan will have it's gateway on the layer 3 SVI and the switch will have a default route pointing to the firewall.
Pranay Prasoon
Level 8
Level 8
Hi Mahima,
which device either firewall or switch will route traffic is based on the default gateway configured on host
Example
                      Trunk
  vlan 1----sw------------fw
               vlan 250
Say vlan 1 machine has IP address 192.168.1.1, switch svi 1 has ip address 192.168.1.2 and fw
has ip address 192.168.1.3
similarly vlan 250 machine has ip address 10.1.1.1 , switch svi 250 10.1.1.2 and and fw vlan 10.1.1.3.
So in your scenario all hosts have FW as default gateway. Therefore to reach to an unknow network hosts will send traffic to fw and fw will route it based on its routing table. if your switch is in L3 mode and rather than specifying fw as gateway if you provide the switch IP address then it will be the responsibility of the switch to do the routing.
So if you need to add another VLAN on sw and point default gateway of hosts to switch, switch will route traffic. However FW are mostly stateful in nature and would expect all two way communication through it. So you cannot have default gateway of vlan 250 to fw and vlan XYZ to switch. In this scenario, you can configure interface of switch going to FW as L3 and point a default-route to FW and configure route for all vlans through switch on FW.
Pranay
Hi Pranay,
Thanks for the explanation. I am new I firewall configuration, there are twao sub interfaces configured on firewall for vlan 60 and vlan 90, I believe which are for interval routing, Kindly confirm
 X0LAN 192.168.1.77255.255.252.0Static1 Gbps Full DuplexDefault LAN
 X0:V60LAN 10.0.80.4255.255.240.0StaticVLAN Sub-InterfaceDEV/SUP Domain V...
 X0:V90LAN 10.0.128.3255.255.240.0StaticVLAN Sub-InterfaceQA Domain VLAN
and on switch there is a default route to firewall, but on all the hosts default gateway is also considered as firewall.
Kindly explain me how can I configure route for all vlans through switch on FW.
