Catalyst 4500X Unidirectional Link
Bernhard Mayer
Hi all,
I want to create a unidirectional Link between two catalyst 4500X.
Switch 1:
interface TenGigabitEthernet1/1
 unidirectional receive-only
end
Switch 2:
interface TenGigabitEthernet1/2
 unidirectional send-only
end
Problem:
Switch 1 --> Port notconnect
Switch 2 --> Port connected
Do I need to configure any more on the switch 1 te1/1 to bring up the interface?
I have changed the 10G spf+ transceiver + cable --> same problem.
When I use 1G spf transceiver instead of 10G spf+ on the same ports --> no problem (???)
IOS Version:  03.05.00.E
Thanks for your support,
Bernhard
8 Replies 8
Hi Bernhard,
Does the port stay up without uni directional configuration?
Also share sh interface <> unidirectional
Madhu
Hi Madu
Ports stay up without uni directional config.
Switch1:
Switch1 #sh interfaces te1/1 unidirectional
Unidirectional configuration mode: receive only
CDP neighbour unidirectional configuration mode: send only
Switch1#
Switch 2:
Switch2#sh interfaces te1/2 unidirectional
Unidirectional configuration mode: send only
CDP neighbour unidirectional configuration mode: off
Switch2#
Bernhard
Can you please share the interface config from both the sides.
Madhu
Switch 1:
 (no) speed nonegotiate
end
Switch 2:
end
Ok. Quite not sure but can you hardcode speed and duplex to see if it helps?
Also worth checking on a diffrent port with a differnt SFP/Cable etc.
Madhu
I can't hardcode speed and duplex on a port with 10Ge sfp+ transceiver.
On different ports same problem (1GE sfp works, 10GE sfp+ doesn't works)
Bernhard
acampbell
Hi Bernhard.
What are the results of the follwing command on both switches:-
show interface ten 1/1 unidirectional
show interface ten 1/2 unidirectional
Alex
Regards, Alex. Please rate useful posts.
Hi Alex
Switch1:
Switch1#
Switch 2:
Switch2#
Bernhard
