inter-vrf routing
Dennis Olvany
Level 2
Level 2
I am looking at possible solutions to provide inter-vrf routing on a 6500. Does the following look workable?
int vlan1
ip vrf forwarding red
ip address 2.3.4.0 255.255.255.0
int lo0
ip policy route-map red
route-map red permit 100
set vrf blue
ip route vrf red 1.2.3.0 255.255.255.0 lo0
int vlan2
ip vrf forwarding blue
ip address 1.2.3.0 255.255.255.0
int lo1
ip policy route-map blue
route-map blue permit 100
set vrf red
ip route vrf blue 2.3.4.0 255.255.255.0 lo1
9 Replies 9
cadet alain
I think you should take a look at this: http://packetlife.net/blog/2010/mar/29/inter-vrf-routing-vrf-lite/
Regards.
Alain.
Dennis Olvany
Level 2
Level 2
Thanks for the suggestions. I have noticed a number of solutions on the web that require bgp. Does this look like a method that may work without bgp?
I suppose ip unnumbered would be required on the loopbacks.
nm
Edison, I am familiar with the methods you have referenced. I am curious if PBR is also a viable solution since the feature addition of Multi-VRF Selection Using Policy Based Routing.
you need the route-target import | export feature.
Edison, there seems to be some contention regarding whether pbr can provide an inter-vrf routing function. The documentation below seems to be clear on this point. My inquiry was geared towards the validity of using loopbacks for pbr as referenced in the configlet. Of course, it would also be a dealbreaker if pbr could not provide inter-vrf routing as you seem to imply.
http://www.cisco.com/en/US/docs/ios/12_2sr/12_2srb/feature/guide/srb2mvrf.html
You could leak between global and VRF but not between VRFs with static
http://blog.ipexpert.com/2010/12/01/vrf-route-leaking/
Well also look for vrf route leaking.. its simple between vrf and global.. simply point static routes in vrf with next hop as global and vice-versa. havent tested with inter-vrf.. but worth a try.
Sebastian
