Interconnect 2 VSS and certain port ping problem
rvcitsupport
We have the datacenter network as the attached image.
Description:
+ VSS-CORE:
2 switches: WS-C4506-E
Sup: WS-X45-SUP8-E
IOS: 03.06.03.E
VLAN: 151
+ VSS-SRV:
2 switches: WS-C4510R+E
Sup: WS-X45-SUP8-E
IOS: 03.06.03.E
VLAN: 143
+ The 2 VSS connected using 1 layer 3 port channel and EIGRP routing
+ Everything is OK except port Gi2/7/41 on VSS-SRV:
-PC connected to this port can ping to its gateway, but it CANNOT ping VLAN on VSS-CORE.
-If we move this PC to other ports (for example Gi2/7/40) with the same port configurations and same IP address, all PINGs are OK.
* If PC connected to non-working port (Gi2/7/41) and we shutdown 1 port from VSS-SRV to VSS-CORE (Te1/5/3
on VSS-SRV), the problem will disappear.
The problem is too weird with us. Could you give me any suggestion?
Thanks in advanced!
andreassb
Level 4
Level 4
Do the two VSS domains have different ID's?
"switch virtual domain xyz"
Hi andreassb,
Thanks for your attention,
We did configure different virtual domain id on the 2 VSS.
VSS-CORE: switch virtual domain 1
VSS-SRV: switch virtual domain 101
Note that the problem happens with only 1 port  Gi2/7/41.
