Interface errors on 6509
s-kirk
Community Member
Since upgrading our core 6509 to a brand new 6509 sup720 we have noticed some strange Receive Errors on a number of interfaces. These interfaces all share common characteristics - they are all access ports, connecting to identical switches.
The errors are shown below
SRPCC#sh interfaces gigabitEthernet 1/2 counters errors
Port Gi1/2 Rcv-Err 7874
SRPCC#sh interfaces gigabitEthernet 1/2 counters trunk
Port Gi1/2 WrongEncap 7874
This would indicate an error with the trunking configuration but this is the config of the interfaces.
Core switch (this is interface with errors)
interface GigabitEthernet1/2
no ip address
switchport
switchport access vlan 103
switchport mode access
switchport nonegotiate
spanning-tree cost 3
end
Access switch
interface GigabitEthernet0/1
spanning-tree portfast disable
spanning-tree vlan 1 cost 4
end
I know we are bridging the VLAN's but this has been the design for some time. Prior to the 6509 upgrade we were not seeing these errors.
The errors also occur one every 30 seconds which would lead me to think it is DTP, but switchport nonegotiate should disable DTP completely.
Any ideas?
Could it be somehow connected to new modules/software ability to customize EtherType?
I mean that old software simply didn't check this field in packets header but the new one checks and generates the error.
//Mikhail Galiulin
I was already thinking along these lines as the old 6509's were running hybrid with sup1a's and MSFC 1 cards. CatOs was version 6.3
As part of the upgrade we migrated to running native.
If this is the case - ie it's new functionality in the code picking up the error, is there anything that can be done to stop the errors being reported? Or more to the point what could be causing the WrongEncap error?
