Interface Interpretation
Hello Community,
Can someone please explain why the BW on Dialer1 is 56 Kbit/Sec, while the Virtual-Access2 (that the Dialer 1 is bound to) has a BW of 448 kbit/s?
uk01340-rm01-ald#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
uk01340-rm01-ald(config)#end
uk01340-rm01-ald#show int dial 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is 80.229.xxx.xx/30
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2d23h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
  5 minute input rate 672000 bits/sec, 91 packets/sec
  5 minute output rate 358000 bits/sec, 62 packets/sec
     11406560 packets input, 1877304168 bytes
     9925735 packets output, 18446744072806663030 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 448 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 216/255, rxload 255/255
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer1
  Vaccess status 0x44
  Bound to ATM0/1/0 VCD: 1, VPI: 0, VCI: 38, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 672000 bits/sec, 92 packets/sec
  5 minute output rate 380000 bits/sec, 89 packets/sec
     11429126 packets input, 1875972366 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     9925741 packets output, 3392079954 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
And if I were to monitor the interface, should I monitor the Dialer 1 interface or the Virtual-Access 2 interface?
Cheers
Carlton
8 Replies 8
Richard Burts
Carlton
I do not have an authoritative answer, but here is what makes sense to me. Both interfaces are virtual interfaces and therefore do not have any physical implementation from which a realistic and accurate bandwidth can be determined. So Cisco must make a choice about what to use for the interface bandwidth. Dialer interfaces have been around a long time and in their beginning were closely associated with ISDN. So the choice of 56K is appropriate for them. The virtual access interface is much more recent and is not so much associated with any physical interface. So Cisco has chosen a higher value for the bandwidth, which is in keeping with the tendency to use higher and higher capacity media in our networks.
Rick
Rick
Leo Laohoo
What is the exact model of this router?
If this is a xDSL router, issue the command "sh atm dsl".
Leo,
Sorry for the delayed response.
Please find the information as requested:
uk01340-rm01-ald#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
uk01340-rm01-ald uptime is 5 days, 19 hours, 46 minutes
System restarted at 15:52:45 BST Fri Sep 13 2013
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX16378390
1 DSL controller
1 Ethernet interface
2 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
uk01340-rm01-ald#show atm interface atM 0/1/0
Interface ATM0/1/0:
AAL enabled:  AAL5,, Maximum VCs: 4, Current VCCs: 1
VCIs per VPI: 1024,
Max. Datagram Size: 1658
PLIM Type: ADSL - 448Kbps Upstream, DMT, TX clocking: LINE
146173 input, 216668 output, 14275586 IN fast, 11353720 OUT fast
Avail bw = 448
Config. is ACTIVE
uk01340-rm01-ald#
Cheers
Errrr ... That's not the command I was asking.  What is the output to the command "sh atm dsl"?  This output will tell you your sychronized speed with your ISP.
Hi Leo
I don't have that option:
uk01340-rm01-ald#show atm ?
  acircuit            ATM Attachment circuit information
  arp-server          ATM ARP Server Table
  async               Display ATM Async Interface Information
  bundle              ATM bundle information
  capabilities        ATM capabilities
  cell-packing        ATM cell-packing information
  class-links         ATM vc-class links
  ilmi-configuration  Display Top level ILMI
  ilmi-status         Display ATM Interface ILMI information
  interface           Interfaces and ATM information
  map                 ATM static mapping
  oam                 ATM oam
  pvc                 ATM PVC information
  traffic             ATM statistics
  vc                  ATM VC information
  vlan                Display VLAN to PVC bindings
  vp                  ATM VP information
Carlton
Or was it "sh DSL ATM".
Sent from Cisco Technical Support Nintendo App
Try
show controller vdsl
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
paolo bevilacqua
Wrong forum, post in "WAN and routing". You can move your posting with the Actions panel on the right.
