interface name FastEthernet0/4 or FastEthernet1/0/4
Hi there,
Trying to have a better understanding on how this interfaces are named
when are they named like this 0/4 ?
and when like this 1/0/4?
while I get the last digit is the no. of the port, what are the other digits standing for? no of the switch? and?
thanks for any tips
DanielP211
The explanation should be like this. The Fastethernet/ethernet/gigbitethernet is the speed, and the numbers are:
Gig2/0/32
<switch>/<module>/<switchport>
Is Switch 2 (inside stack), Module 0 (only one module on the switch), port 32.
BR
****Kindly rate all useful posts*****
DanielP211
Gig2/0/32
BR
DanielP211
*The module can also be module/slot number.
Mark Elsen
 -  Interface  FastEthernet1/0/4 indicates 1st module of the switch and its port number 0/4 ; so the 3 digits are used when you have multiple modules ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
A standard switch you are used to usually come with the ethernet/fastethernet/gigethernet ports bundles with the device. so they are usually names as bundled/port. so if you are interested in the 5th port of a 24-port switch for example, it is 0/5. however, a lot of Cisco Hardwares come with modular bays, ie empty slots where you can fit in different media cards. now assume you have a hardware with 2 media bays (bay 1 and bay 2) in addition to the bundled ports. if you buy a 24 port fast ethernet card and slot it into bay 1, and again you are interested in the 5th port of the new card, it is designated as fastethenet 1/0/4, if on the other hand you slotted it into bay 2, you have fae2/0/5
