interface on supervisor modul not up
jenseike
Level 2
Level 2
Hi all..
I have two new 4503 cat`s with Sup II+TS 10/100/1000BaseT supervisor module in.. This is set up in slot 1 of the chassie... the modul have 12 GE ports (RJ45) and 8 SFP ports..
I am not able to get the interfaces in up mode. I have put in a RJ45 in port 1/12 of each switch connected to each other.
L3-Core#1#sh module all
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 20 Sup II+TS 10/100/1000BaseT (RJ45), SFP WS-X4013+TS JAE10318CQ5
2 24 10/100/1000BaseT (RJ45) WS-X4424-GB-RJ45 JAE102022K6
M MAC addresses Hw Fw Sw Status
1 0018.187a.5fc0 to 0018.187a.5fd3 1.5 12.2(20r)EW1 12.2(25)EWA4 Ok
2 0016.c73c.ed28 to 0016.c73c.ed3f 1.8
interface GigabitEthernet1/12
switchport access vlan 1000
speed 100
duplex full
spanning-tree portfast
L3-Core#1#sh run int vlan 1000
Building configuration...
Current configuration : 108 bytes
interface Vlan1000
ip address 10.0.14.1 255.255.255.0
but the port is showing down:
L3-Core#1#sh int g1/12
GigabitEthernet1/12 is down, line protocol is down (notconnect)
I have tried to change cable, but same problem...
What am I missing here????
L3-Core#1#sh ip int brie
Vlan1 192.168.222.244 YES NVRAM up up
Vlan1000 10.0.14.1 YES NVRAM down down
GigabitEthernet1/1 unassigned YES unset down down
GigabitEthernet1/2 unassigned YES unset down down
GigabitEthernet1/3 unassigned YES unset down down
GigabitEthernet1/4 unassigned YES unset down down
GigabitEthernet1/5 unassigned YES unset down down
GigabitEthernet1/6 unassigned YES unset down down
GigabitEthernet1/7 unassigned YES unset down down
GigabitEthernet1/8 unassigned YES unset down down
GigabitEthernet1/9 unassigned YES unset down down
GigabitEthernet1/10 unassigned YES unset down down
GigabitEthernet1/11 unassigned YES unset down down
GigabitEthernet1/12 unassigned YES unset down down
Ports in the linecard modul are no problem. they are up when I plug the cord in them...
Jens
glen.grant
Vlan 1000 will not come up unless you have a live port in vlan 1000 . You would have to get alive connection on g1/12 and you will then see the layer3 SVI come active .
