05-10-2016 12:51 AM - edited 03-08-2019 05:40 AM
Hello Guys,
Linux Users connected to my Access user switch are complaining about latency.
I Checked the sw interfaces : Does any one now why do I have output drops pleaaase ?
| User int speed configuration on PC | sw Interfaces | ||
| 127 input errors, 120 CRC, output drops: 6560435 | 1Gb | G4/0/35 | |
| 65 input errors, 59 CRC, output drops: 4118716 | 1Gb | G4/0/31 | |
| 53 input errors, 49 CRC, output drops 2072336 | 1Gb | G4/0/28 | |
| output drops 94122 | 1Gb | G3/0/15 | |
| output drops: 2539 | 1Gb | G4/0/30 | |
| 148 input errors, 137 CRC, output drops 29049107 | 1Gb | G3/0/21 | |
| output drops: 3923988 | 1Gb | G2/0/24 | |
| output drops: 302659 | 1Gb | G1/0/9 | |
| Disabled | 1Gb | G3/0/44 | |
| output drops: 2536 | 1Gb | G3/0/14 | |
| output drops: 1350036 | 1Gb | G1/0/22 | |
| output drops: 9428 | 1Gb | G2/0/7 | |
| output drops: 74435 | 1Gb | G2/0/22 | |
| output drops: 54846 | 1Gb | G3/0/9 | |
| output drops: 5092185 | 1Gb | G1/0/2 | |
| output drops: 159657 | 1Gb | G2/0/15 | |
| output drops: 630711 | 1Gb | G2/0/34 | |
| Not connected | 1Gb | G4/0/38 | |
| 72 input errors, 56 CRC, output drops: 10383796 | 1Gb | G4/0/37 | |
| output drops: 1413181 | 1Gb | G4/0/39 | |
| output drops: 58514 | 1Gb | G1/0/26 | |
| output drops: 237431 | 1Gb | G2/0/33 | |
| 9162 input errors, 8676 CRC, output drops 82234343 | 1Gb | G1/0/39 | |
| 925 input errors, 862 CRC, output drops 1846412 | 1Gb | G1/0/35 |
Solved! Go to Solution.
05-16-2016 02:39 AM
Not really in logs for something like that you would need to check it with show int status
you could do it in prime in compliance but it would need to run and check and then report on it , standard cisco logs wouldn't pick something like that up when its set to auto negotiate
if someone is changing it on the router itself you could do it by archiving to see how and when and what they changed it and were logged in
05-26-2016 01:03 AM
Hello Mark, I hope you are doing fine. I was hoping getting some help about this situation :
I want to prouve if my users latencies are coming from the output drops on users interfaces.
Below a sh int of a user interface :
we see 275254 drops in 1d16h up time.
QOS is configured on my user interface. Could we now from which queue these drops are comming.
Here is a sh run int of the interface.
Many thanks for your help.
05-26-2016 04:51 AM
this command alone can be known to introduce slight latency as your telling router to wait service them 1st then when its empty service other queues ------ priority-queue out
to see queues in mls use the show mls qos interface gx/x statistics
Have you checked the path as well that they are taking src - dst ran a tracert or traceroute or mtr to see where the delay/latency is to make sure its not qos ?
Have you tried removing qos off the switch to see if the latency is better , qos splits the buffers and can cause issues as well on certain platforms like 3750s or alter teh srr queues as well for the drops
