interface Output drops. Lan users complain about latency.
Marc_AMI1
Hello Guys,
 Linux Users connected to my Access user switch are complaining about latency.
I Checked the sw interfaces : Does any one now why do I have output drops pleaaase ?
User int speed configuration on PC sw Interfaces
 127 input errors, 120 CRC, output drops: 6560435 1Gb G4/0/35
 65 input errors, 59 CRC, output drops: 4118716 1Gb G4/0/31
53 input errors, 49 CRC, output drops 2072336 1Gb G4/0/28
 output drops 94122 1Gb G3/0/15
output drops: 2539 1Gb G4/0/30
   148 input errors, 137 CRC, output drops 29049107 1Gb G3/0/21
output drops: 3923988 1Gb G2/0/24
output drops: 302659 1Gb G1/0/9
Disabled 1Gb G3/0/44
output drops: 2536 1Gb G3/0/14
output drops: 1350036 1Gb G1/0/22
output drops: 9428 1Gb G2/0/7
output drops: 74435 1Gb G2/0/22
output drops: 54846 1Gb G3/0/9
output drops: 5092185 1Gb G1/0/2
output drops: 159657 1Gb G2/0/15
output drops: 630711 1Gb G2/0/34
Not connected 1Gb G4/0/38
72 input errors, 56 CRC, output drops: 10383796 1Gb G4/0/37
output drops: 1413181 1Gb G4/0/39
output drops: 58514 1Gb G1/0/26
output drops: 237431 1Gb G2/0/33
9162 input errors, 8676 CRC, output drops 82234343 1Gb G1/0/39
  925 input errors, 862 CRC, output drops 1846412 1Gb G1/0/35
Mark Malone
Are those input drops/crcs incrementing constantly on each interface above that has them?
when were they last cleared ?
The crcs with inputs could mean a bad cable or nic its layer 1 issue but you need to check if theses are constantly going up in real time , if there not then that's not the issue
17 Replies 17
Mark Malone
Yes cleared it frequently. And i get 500 output drops per our :(
The output drops are completely different from crcs and input errors there layer 1 problems , if you see these errors increasing after clearing the counters you need to check the cabling , either replace it or check if there are issues with it using command below , fix the issue and retest
test cable-diagnostics tdr interface gigabitEthernet x/x
show cable-diagnostics tdr
Output drops can be from spiked traffic micro bursts of traffic caused by certain applications or from overutilization of the interface itself the buffer being filled as too much traffic for it to handle , are you running qos on these interfaces
When there complaining about latency have you checked to what destination there going and run a traceroute to it from there pc and see if you see any delays in the hops of the path to the destination
I would be fixing the interfaces with incrementing crcs and inputs before looking into output drops
Hi mark,
Thaks a lot for your answers.
What do you mean by : I would be fixing the interfaces with incrementing crcs and inputs before looking into output drops.
As i dont see any CRC since i cleared the interfaces counters
Ok well that's good if you cleared the counters and there not there anymore that means your layer 1 is ok as that would cause issues for the end users more than output drops would.
Have you calculated the amount of drops per volume of traffic in the interfaces , if its less than 1% its ok but if its more than that you will need to try and see whats causing it
can you take one of the worst interfaces and post the full show interface gx/x and also the show run int gx/x off that interface
from that we might be able to see a bit more if its over utilized etc
As well you need to confirm there is actual latency from the user pc as well and if its just with certain destinations there trying to get to , certain applications they use or is it with every time there on the network or is it only LAN or just when crossing WAN
Are these interfaces constantly running hot at on the RX/TX , are they hammering the ports etc , these are just some things to check as even if there is output drops it shouldn't really be causing them noticeable latency unless the switch is completely oversubscribed , try find the common problem between the users
You have multiple modules there its hard to think they would all be oversubscribed at access layer , the issue may not be the output drops
Thanks a lot for the help.
SW-FRPAU-X00I1B-AUSR#sh int g3/0/21
GigabitEthernet3/0/21 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e05f.b9f8.4a15 (bia e05f.b9f8.4a15)
  Description: *** STATION LINUX ***
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 1w6d, output 00:00:19, output hang never
  Last clearing of "show interface" counters 03:39:25
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 86274
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 51000 bits/sec, 48 packets/sec
  5 minute output rate 1225000 bits/sec, 92 packets/sec
     10479475 packets input, 905676618 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     18115443 packets output, 23193919694 bytes, 0 underruns
sh run :
interface GigabitEthernet3/0/21
 description *** STATION LINUX ***
 switchport access vlan 50
 switchport mode access
 switchport voice vlan 850
 ip arp inspection trust
 ip arp inspection limit rate 100
 no logging event link-status
 no logging event power-inline-status
 speed auto 100 1000
 srr-queue bandwidth share 12 8 30 50
 queue-set 2
 priority-queue out
 no snmp trap link-status
 storm-control broadcast level 50.00
 spanning-tree portfast
 spanning-tree bpduguard enable
 ip dhcp snooping limit rate 100
 ip dhcp snooping trust
end
Way too many drops in 3hrs uptime , Looks like you running qos and your running priority queuing which means everything in priority queue will be serviced first in qos but you have bound the qos to the queue set 2 instead of default queue 1 in the module and then given a custom queue set in srr , im guessing you did not originally set this up as this looks like it was done for a reason if they applied queue set 2 to the interface and given specific custom weightings
These drops could be from the way that's setup , your telling interface only care about priority queue first so drops will occur due to this
: Priority queue is serviced until empty before the other queues are serviced in qos
Qos can be responsible for drops depending on the way its configured , sometimes interfaces experience a lot less drops without qos at layer 2
queue-set 2
priority-queue out
You need to check are these drops been seen in qos in the interface , is MLS qos enabled globally post the below off that interface if it is and we can check is qos seeing drops
sh mls qos interface gigabitEthernet x/x statistics
There are a couple of things you can try to fix this
1 Manipulate the srr queues so that any queue that's seeing major drops is given more available percentage. the ssr adds up top 100% and is divided between the queues in the interface  12 8 30 50 = 100 , and it must always equal 100 but you can alter them say if all the drops were in queueu 4 but none in queue 3 as an example you could change it too 12 8 20 60 = 100
2 Remove qos and just use the mls qos trust so there is no queue prioritisation and the voice is still trusted as phone will mark at the source
3 Remove just the priority statement to stop the queue starvation
Its all about getting the right fit for your traffic and environment when using layer 2 qos
These are options only don't change everything at once take a test interface make a few changes and when you get it right with 1 roll it out to the rest
As well if your using different modules in the switch each have different queuing capabilities like below example this can also guide in what the module hardware is capable of
#sh int g1/4/1 capabilities
GigabitEthernet1/4/1
  Model:                 NO IDPROM
  Type:                  unknown (4)
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(off,on,desired)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(1q8t), tx-(1p3q8t)
  QOS queueing mode:     rx-(cos), tx-(cos)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  Inline power policing: no
  SPAN:                  source/destination
  UDLD                   yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  Ports-in-ASIC (Sub-port ASIC) : UNAVAILABLEnum_bus = 0, num_ports = 0
  Remote switch uplink:  no
  Port-Security:         yes
  Dot1x:                 yes
Hey Marc,
I thought you said that less than 1% drops per volume of traffic in the interface is ok.
because with 86274 drops for 18115443 ouput traffic is < 1%.
Please correct me if i am wrong :)
I attached a show mls qos screen shot.
Many thanks again
Yes that's correct less than 1% is fine but we need to make sure the correct packets are being dropped when qos is in place it changes things as it introduces queuing in buffers, dropping 1% of priority traffic is not good but if it’s being dropped in the correct queues then you’re ok
Looking at that MLS output it looks good, the drops are in q4 (I know it says 3 its just the way you count them 0-3 4th queue)
That’s the queue you have given the most bandwidth too 50 which is usually least prioritized queue in your setup so that’s where we would expect to see a few drops as could be bulk traffic etc
You could increase the queue but you risk effecting your other queues which have more prioritised DSCP values like EF and AF traffic
Again you could remove qos as a test and see if it resolves their latency issue but only a test interface / module
I would start looking at why the users specifically in more details are facing latency as said earlier , is there a common issue , destination / app etc that there using that they see a problem, is the issue there at layer 3 or just at the application layer etc
Check what type of applications there using locally on the pcs check if there known for burst traffic which can cause these output drops as well or if the issue is nothing to do with this switch either and is to do with the path they take to their destination
Hello Mark,
I just find out that users  ports  change  their speed to 10mb/s some times.
the variatin of speed on interfaces please ?
Many thanks,
Hey Paulinho
If I understand you right and there changing there nics to 10mb and you have the user port to only work with 100 1000 above your going to introduce crc errors as the speed settings will be different on both sides
you need to set your port to speed auto 10 100 1000
Hi Marc,
Is there any way to log those speed variations so i can see them when i perform a show logg ?
Many thanks again,
If there setting the speed and its not supported on the interface it should kick them out go up/down , if the duplex mis-match the error will show in logs anyway as a problem
I see what you mean.
But is there a way to see  in log when a interface change from 1000 to 100 for instance ?
Thanks again for your help
