Interface port-channel error message
rfuentes1111
Level 3
Level 3
Hi Team,
I'm getting the following error when i try to enter the following command into et3/2 interface on a KN7 any help will be appreciate thank you.
sh run int po105
interface port-channel105
description 10.197 (SS105005)
switchport
switchport mode trunk
switchport access vlan 10
switchport trunk native vlan 10
N7K1(config)# int et3/2
N7K1(config-if)#
N7K1(config-if)# switchport trunk native vlan 10
N7K1(config-if)# switchport mode trunk
N7K1(config-if)# channel-group 105 mode active
command failed: port not compatible [port access VLAN]
** You can use force option to override the port's parameters
** (e.g. "channel-group X force")
** Use "show port-channel compatibility-parameters" to get more information on failure
7 Replies 7
Reza Sharifi
Try this:
no interface port-channel105
exit
int et3/2
exit
switchport
no sh
and test again.
By doing this it will be deleting the inteface port-channel 105 then it will create the channel again is that correct.
Yes, that is correct.  From that point forward you just add any config line to the Portchannel and the physical interface will inherit it.
Carlos Villagran
Hi!
This error appears when you try to bundle two interfaces which has no identical configuration. Please be sure that all links you are trying to bundle into your port-channel 105 have the same configuration.
Have a nice day, best regards!
JC
You have a port-channel interface configured like this:
interface port-channel2
  description --- port-channel ---
  switchport
  switchport trunk allowed vlan 101
Member interfaces must have the same configuration before entering the port channel.
If not, here's what happens.
ITESYS_nexus7400# sh run int eth4/3
interface Ethernet4/3
  description --- port 1A ---
  no shutdown
ITESYS_nexus7400# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ITESYS_nexus7400(config)# int ethernet 4/3
ITESYS_nexus7400(config-if)# channel-group 2
command failed: port not compatible [switching port]
The switch basically tells you that it can do this job for you if you use the force option.
So I try again.
ITESYS_nexus7400(config-if)# channel-group 2 force
No error reports now. But the interface will automatically be configured with the parameters of the port-channel interface:
ITESYS_nexus7400# sh run int ethernet 4/3
  switchport
  channel-group 2
  no shutdown
switchport mode trunk <- this make port trunk
switchport access vlan 10 <- then you add this command which overrride the above one and make port access port
hence the PO not work because it see now port as access not trunk
quocbinbin@gmail.com
Frequent Visitor
Frequent Visitor
port channel vs port physical need same mode access or trunking
