08-16-2010 12:45 AM - edited 03-06-2019 12:29 PM
dear experts,
i have a Cisco 877 router and found 2 interface resets on the WAN link. please advise what can cause this? i checked the router's syslogs and found no downtime.
ROUTER#sh int FastEthernet0/0
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0021.a04f.82cc (bia 0021.a04f.82cc)
Internet address is 202.x.x.x/30
MTU 1500 bytes, BW 4096 Kbit, DLY 100 usec,
reliability 255/255, txload 159/255, rxload 165/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1y17w
Input queue: 9/75/128500/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2655000 bits/sec, 840 packets/sec
5 minute output rate 2558000 bits/sec, 795 packets/sec
3339260229 packets input, 4106417120 bytes
Received 96 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
2910129777 packets output, 70561370 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets --> ???
0 lost carrier, 0 no carrier
ROUTER#sh log | i FastEthernet0/0
ROUTER#
Solved! Go to Solution.
08-16-2010 01:26 AM
The counters haven't been cleared in over a year.
The resets could have happened a long time ago. You may want to clear the counters and monitor the interface
08-16-2010 01:26 AM
08-16-2010 01:48 AM
thanks! i've overlooked on that one (last clearing). i did a clear counters and will monitor from here. thanks a lot!
