Interface Tunnel Bandwidth
Mokhalil82
Level 4
Level 4
I have been provided a 500MBPs link from the ISP which terminates into G0/0 on my router. I will be using 2 x  DMVPN  tunnel interfaces on this physical connection. Do I need to set the tunnel bandwidth to 250MBPS per tunnel or is it better to use 500MBPS per tunnel.
I understand the command may not affect the traffic load allowed but instead is used by routing, QOS etc but m just curious what people would usually do
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What I usually do is have tunnel bandwidth reflect the expected amount of bandwidth expected to be available across the tunnel between two locations.
Joseph W. Doherty
Disclaimer
Posting
