Interface VLAN in Router
ashish
Dear All,
Kindly let me know, when do we create interface vlan in the router. Would appreciate if you can support with an example.
Ash
5 Replies 5
glen.grant
In a router the only time you will use a SVI is if you have some of the hwic etherswitch cards installed . The only way to put an address on those is to use a SVI and put the port in a vlan , you cannot make the etherswitch ports a routed port.
Glen,
Thanks for the prompt response, could you please share some scenarios/examples/case studies.
Glen,
Understood the setup as required.Would appreciate if you can share some scenario etc.
Thnx
Ash
jiaowenbin
In the past , when the L3 switches are not popular , Creating vlan in the router is very often , but now ,L3 switches are very cheap , Vlan in router is not used as often as before.
