Interface VLAN
abraham.vasquez
Community Member
I am trying to set a specific Ip address on a interface VLAN. When I check the configuration it shows me a # on the Ip address and on top it says "no ip address". I have assigned the VLAN to a port and had a device plugged in. When I check the config, the results are the same. I am trying to understand if that means the Ip address was not accepted or perhaps some configuration is missing.
interface vlan 550
no ip address
# ip address 10.0.97.254 255.255.255.224
no shutdown
interface vlan 210
no ip address
# ip address 10.128.3.254 255.255.254.0
no shutdown
balaji.bandi
Not sure is this output from the device ?
why there is #before  ip address  ?
try below
config t
interface vlan 550
no shutdown
interface vlan 210
no shutdown
end
still not working post below output : ( along with what is this device, what IOS code running)
show run
show vlan
show ip interface brief
BB
Mark Elsen
 - You may try to shutdown the vlan interface (again) and for instance use : default interface vlan 550 , then set the ip address again, followed by no shutdown.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Georg Pauwen
what device is this on, and what IOS version are you running ?
Try to default the interface, or delete and recreate it:
no interface vlan 550
Interface vlan 550l
Giuseppe Larosa
Hello @abraham.vasquez ,
check if ip routing is enabled
you need in global config
ip routing
if you try to configure mutliple SVI Vlan interfaces with IP addresses on a switch that is not running IP routing you can have issues
post show version
In the past on L2 only devices like Cat 2950 when enabling a second SVI with IP address the other one that was present was shutdown.
Hope to help
Giuseppe
