interface vlans
lkadlik
hi,
i am running
     WS-C2960G-48TC-L   12.2(25)SEE3            C2960-LANBASE-M
I know I can do interface vlans but will I be able to do basic routing to another network using the interface vlans
The end goal is to have a switch uplink to another switch that has servers off it that need to talk to a storage device.
Thank you.
Lynne
Richard Burts
Lynne
It is my understanding that in release 12.2(55)SE they added the ability to do static routing, which might be sufficient for your requirements - if I have read correctly what your requirements are. However the code in your switches is older and therefore I do not believe that you could do the routing in this switch - at least not without a code upgrade.
Rick
Rick
Hello
Like to jsut add to Ricks comments  -Although it doesnt support routing protocols, it does indeed allow static and default routes when sdm prefer lanbase-routing is enabled using 12.2(55)SE and above
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swipstatrout.html
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
mvsheik123
Level 7
Level 7
Check the below posting. You may need IOS upgrade.
https://supportforums.cisco.com/thread/2196481
hth
MS
