03-31-2024 05:50 AM - edited 03-31-2024 05:53 AM
Guys, I didn't see any configuration problems with the LACP, the SFP or the link/fiber.
But I have a topology with a LACP between 9500 x 9400, and I use 4 10G-SR interfaces.
One of these interfaces is passing TX input traffic, but not RX output.
I removed the portchannel interface, configured a static IP, and I see traffic passing in both directions, however, when I return to the portchannel, it has no traffic.
There is no CRC, and I also didn't see any difference in voltage, current, or tx/rx in the tranceiver detail.
It seems to be something from LACP, but I haven't seen any bugs, and the equipment is not supported.
As there are 2 interfaces, I recommended the customer to disconnect one that is functional, and place it in the position of the ones that are not receiving traffic, however, as I said, it seems to be something in the lacp.
any other tips?
Below I compare the particularities of a functional transceiver, and another with an interface with a problem:
9500:
SW-WAN-01#show interface Twe1/0/37 | inc rate
Queueing strategy: fifo
30 second input rate 14488000 bits/sec, 6898 packets/sec
30 second output rate 3863000 bits/sec, 4057 packets/sec
SW-WAN-01#show interface Twe1/0/36 | inc rate
5 minute input rate 27002000 bits/sec, 3303 packets/sec
5 minute output rate 3475000 bits/sec, 3429 packets/sec
SW-WAN-01#show interface Twe2/0/37 | inc rate
30 second input rate 20007000 bits/sec, 2843 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
SW-WAN-01#show interface Twe2/0/36 | inc rate
30 second input rate 25204000 bits/sec, 3618 packets/sec
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Twe2/0/37 22.6 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Twe2/0/37 3.32 3.63 3.46 3.13 2.97
Current Threshold Threshold Threshold Threshold
Port Lane (milliamperes) (mA) (mA) (mA) (mA)
Twe2/0/37 N/A 4.1 10.0 8.5 3.0 2.6
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port Lane (dBm) (dBm) (dBm) (dBm) (dBm)
Twe2/0/37 N/A -2.2 1.7 -1.3 -7.3 -11.3
Receive Power Threshold Threshold Threshold Threshold
Twe2/0/37 N/A -3.1 2.0 -1.0 -9.9 -13.9
9400
COE-CRP-01#show interface T2/1/0/3 | inc rate
5 minute output rate 22741000 bits/sec, 3218 packets/sec
COE-CRP-01#show interface T2/1/0/6 | inc rate
5 minute output rate 18305000 bits/sec, 2629 packets/sec
COE-CRP-01#show interface T1/1/0/3 | inc rate
5 minute input rate 3683000 bits/sec, 3510 packets/sec
5 minute output rate 25529000 bits/sec, 3196 packets/sec
COE-CRP-01#show interface T1/1/0/6 | inc rate
5 minute input rate 3910000 bits/sec, 3720 packets/sec
5 minute output rate 12504000 bits/sec, 3834 packets/sec
COE-CRP-01#show running-config interface po101
Twe1/0/37 21.9 75.0 70.0 0.0 -5.0
Twe1/0/37 3.33 3.63 3.46 3.13 2.97
Twe1/0/37 N/A 4.5 10.0 8.5 3.0 2.6
Twe1/0/37 N/A -2.2 1.7 -1.3 -7.3 -11.3
Twe1/0/37 N/A -2.9 2.0 -1.0 -9.9 -13.9
Solved! Go to Solution.
03-31-2024 04:49 PM
No problem,
Looks like the 9500 will have more entropy hashing on the 5-tuple, I'd config the 9400 to match the 9500 hash load-balance as of now it just hashes based on d-mac and d-ip which might be causing what you're seeing. The more tuples we match on the more entropy for hashing across your etherchannel link. Once you do that check your int counters again and see if the traffic is rx/txing where/how you expect.
Cheers
03-31-2024 01:57 PM
It may just be the load balancing algorithm pinning the rx traffic to the other link. The "port-channel load-balance ?" In global config should show you the available load balancing options. See here for relevant commands to configure the hash algorithm:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cether/command/ce-cr-book/ce-m1.html#wp1124464550
Hope that helps,
Alan
03-31-2024 02:15 PM
Share
Show port-channel load
Of both SW let compare the algorithm use in both SW
MHM
03-31-2024 04:39 PM
Hello @alancelliott and @MHM Cisco World
Thank you very much!
Now with this information, I'm going to study a little more to understand what is leading to this strange behavior.
Anyway, thank you very much.
9500
SW-WAN-01#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-mixed-ip-port
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address and TCP/UDP (layer-4) port number
IPv6: Source XOR Destination IP address and TCP/UDP (layer-4) port number
SW-WAN-01#show run interface port-channel 101
Building configuration...
Current configuration : 270 bytes
interface Port-channel101
description [MON]CORE01 - PO101
switchport trunk allowed vlan 13,14,100,101,156,210,224,251,1266,2240 ,2340
switchport trunk allowed vlan add 2638,3000,3924,3962,4007
switchport mode trunk
load-interval 30
speed nonegotiate
9400
CRP-01#show etherchannel load-balance
src-dst-ip
CRP-01#show run interface port-channel 101
Current configuration : 258 bytes
description [MON]SW-WAN-01 - PO101
switchport trunk allowed vlan 13,14,100,101,156,210,224,251,1266,224 0,2340
load-interval 30
03-31-2024 04:49 PM
No problem,
Cheers
04-02-2024 11:51 PM
sorry I see your reply today
mixed is advance feature from cisco to for load balance
so match both Hash in both SW and check load in links
MHM
