srr-queue bandwitdh limit 90
Adnan Razi Khan
Is this command rate limit the traffic passing through switch port.
srr-queue bandwitdh limit <10-90> enter bandwidth limit for interface as percentage.
If I want to pass 9 mbps traffic through a switch port what command i will need or if i need 22 mbps then what value i should use.
As @balaji.bandi correctly describes it set as a percentage of port's physical bandwidth.
BTW, I recall (?) sometimes there were hardware limitations (platform and/or port specific) such as not supported on every port or percentage wasn't exact.
For exact bandwidth enforcement you might use a policer, but excess is dropped unlike the port queueing excess.
On a FE port, if you wanted 9 Mbps, you run the port at 10 Mbps and use a value of 90.  For 22 Mbps, you run port at 100 Mbps and use a value of 22.  Again, you may find actual bandwidth allowed isn't exactly as specified.
5 Replies 5
balaji.bandi
as per the information there is no exact model of the switch or IOS code mentioned, as per label it says cat 2K switch :
10-90 is the % of the interface.
example if it is fast Ethernet 100MB
9MB means 9% of 100MB (neared is 10MB)
reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swqos.html?bookSearch=true
BB
Adnan Razi Khan
Switch is 2960x by the way. so for 22 mbps should be as below
srr-queue bandwitdh limit 22
speed 100
For 9Mbps
speed 10
Adnan Razi Khan
Appreciate Balaji and Joseph
