Intermitten telnet connection
angkianann
Sorry, I not sure whether this is the correct place to post this question.
I have a server S1 and a load balancer connected to a CISCO switch and a server S2 connected to the load balancer.
The problem is when I tried to telnet from S1 to S2 phyiscal IP address and port, sometimes telnet can be established sometimes it can't. Why is so? There is no configuration on load balancer. I was trying to bypass the load balancer. The error I got is TCP/IP 10054.
Thank you
owillins
Level 6
Level 6
paste your switch running-config.
