Internal HTTP Captures on Inside Interface
WildMan365
I am trying to see HTTP connections from 2 devices both on the same subnet. One device can access another totally fine & there are no communication issues but when I run the captures below I dont see anything show up on the capture. I double checked my capture command to make sure I am capturing the right traffic on the right interface & Im starting to wonder if anything will even show up since both devices are on the same subnet & are probably not crossing the inside interface, they most likely are going layer 2 directly from device to device communicating on the switch not through the router. Should I expect to see anything?
Goodyear# capture I-HHTP interface inside match tcp any any eq 80
Goodyear# sh cap
capture I-HHTP type raw-data interface inside [Capturing - 0 bytes]
match tcp any any eq www
Deepak Kumar
If your both systems on the same subnet then data packet will no send to the gateway. This is the default behavior of TCP/IP process.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
