03-30-2018 06:56 PM - edited 03-08-2019 02:28 PM
Hi, I have 8 switchs SG200-26.
I have one network (192.168.8.0/22). My gatewate is 192.168.10.1.
Could I configure one VLAN for each port of switch, and port of my gateway could I untagged for response all other ports?
My intension is block all acesses between host, for prevent virus between them.
03-30-2018 08:47 PM
03-30-2018 11:56 PM
This is Small Business switch and its support for up to 256 VLANs simultaneously (out of 4096 VLAN IDs). Again it is VLAN only not a Private VLAN. You can configure Each VLAN on each port but there is no VLAN routing feature so you have to extend all VLAN toward your gateway.
This is not recommended to use per port different VLAN and it is not a solution to your issue. It will again make more issues for your network infrastructure such as STP. I recommended to you go with Gateway level antivirus with SSL inspection and choose a good anti ransomware solution for your all systems and configure windows firewall.
Deepak Kumar
