internet connection is slow connected to cisco 2800
Lost & Found
Level 2
Level 2
hi,
Here's my configuration kind check it. Connection to ISP (IDU) - Router (2600) - SW (2950) - Workstation.
Problem: Slow and its loading and loading . but when im directly connected to IDU it's good.
I can ping all the outside interface and it working fine.
thisisatest#sh run
Building configuration...
Current configuration : 1225 bytes
version 12.4
hostname thisisatest
boot-start-marker
boot-end-marker
enable password test123
no aaa new-model
ip cef
username test123 privilege 15 password 0 test123
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 121.96.63.177 255.255.255.240
 no ip redirects
 no ip proxy-arp
 ip nat inside
 no ip virtual-reassembly
 duplex full
 speed auto
interface FastEthernet0/1
 ip address 121.96.66.18 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 ip flow egress
 ip nat outside
 duplex full
 speed auto
ip route 0.0.0.0 0.0.0.0 121.96.66.17
ip route 0.0.0.0 0.0.0.0 111.76.63.179
ip route 10.34.0.0 255.255.0.0 111.76.63.178
ip http server
ip nat inside source static 111.76.63.177 111.76.66.18
control-plane
line con 0
line aux 0
line vty 0 4
 password test123
 login
scheduler allocate 20000 1000
end
Mark Malone
you have 2 default routes , you should only have 1 unless the other 1 is weighted as a backup , your telling hosts going to the internet to go to 2 different addresses as the next hop i would remove the invalid 1 for a start
If you have confirmed the internet connection is good by connecting directly , run a show interface for lan/wan connection as well make sure there are no crcs . inputs collisions etc that might indicate layer 1 issue that can slow down traffic on the router
