Internet Edge Re-design
NETAD
Level 4
Level 4
Hello, we are planning to redesign our internet and this time instead of leveraging the dist/core switch for connecting the firewall and WAN throught L2/L3, there was a suggestion made to place a breakout switch between the core switch, the firewalls and the ISP. For better segregation and throughput.
I need insight and security best practices here please.
1-Im planning to use L3 links between the core and the break out switch in a separate VRF and turn on EIGRP on those
2-use static routes to the firewall
3-L2 vlan for the firewall outside interfaces, and the ISP.
4-is 9300 breakout switch going to offer better throughput for us in this scenario?
5-do I have a solid design here
Muhammad Awais Khan
I would suggest to rely on layer 2 VLANS on the breakout switch instead if going with VRFs. With VRF, you will then required some route leaking between LAN interfaces in global VRF and VRF for wan routers.
Having a breakout switch is good idea, you are saving good interfaces and adding some flexibility to have option for creating subinterfaces.
For the throughput, how much will be the aggregated bandwidth for Internet and WAN links you will be having?. It will be most likely way less than the throughput of the 9300 switch.
Thanks Muhamad, are you suggesting L2 vlans just for the complexity of the config on the breakout switch?
couple ASRs will hang off of the 9ks for Connectivity to the DC and the internet circuit. The pipes range from 150 mbps to 500 I believe.
Hi Muhamad, what are the benefits for having a L3 breakout switch instead of L2
apologizing fo rmissing your comment. L3 breakouts will add more subnets for you which will add more complexity in your design and you have to then add Routing protocols also.
L2 Breakouts will help you also for HA on the ASR side in future, especially if you configure HSRP , which can be possible with L3 Breakout switch but you may endup increase interaces on the Switch side.
In summary, both will work but L3 will increase some extra configuration and overheads for you interms of Routing and additional subnets while L2 will make your Edge side simpler
