Internet Gateway using OSPF Issue
oslopez
Hello everyone,
I have a very basic lab where I'm trying to connect two Cisco routers connected to an Internet gateway (ASA5505) Please see the attached network topology.
If I console to Router A, all works fine, I'm able to ping public servers like 8.8.8.8, etc. Below is the Router configuration:
!Router A
interface GigabitEthernet0/0
 ip address dhcp
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.1.1.1 255.255.255.0
 duplex auto
 speed auto
router ospf 1
 network 10.1.1.0 0.0.0.255 area 0
 network 172.25.10.0 0.0.0.255 area 0
 default-information originate always
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.25.10.1
Internet traffic is forwarded to a default gateway:
RouterA#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
      i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 172.25.10.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.25.10.1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, GigabitEthernet0/1
L        10.1.1.1/32 is directly connected, GigabitEthernet0/1
      172.25.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.25.10.0/24 is directly connected, GigabitEthernet0/0
L        172.25.10.57/32 is directly connected, GigabitEthernet0/0
O     192.168.1.0/24 [110/2] via 10.1.1.2, 00:21:29, GigabitEthernet0/1
And I can reach public hosts:
RouterA#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
Now, if I connect to Router B:
interface FastEthernet0/0
 ip address 10.1.1.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 duplex auto
 speed auto
interface FastEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
router ospf 1
 log-adjacency-changes
 network 192.168.1.0 0.0.0.255 area 0
I can get a default route for internet traffic:
RouterB#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
     172.25.0.0/24 is subnetted, 1 subnets
O       172.25.10.0 [110/2] via 10.1.1.1, 00:17:07, FastEthernet0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/1
O*E2 0.0.0.0/0 [110/1] via 10.1.1.1, 00:16:17, FastEthernet0/0
I can reach Router A, But can't ping any public addresses:
RouterB#ping 8.8.8.8
Success rate is 0 percent (0/5)
Perhaps this is a very easy answer and something is missing in the configuration, but so far I haven't had any luck fixing it.
Any clue would be appreciated.
Thank you.
The routes for the internal subnets shouldn't point to the ISP next hop. but back to router A.
You are telling your ASA how to reach those subnets.
Jon
5 Replies 5
Jon Marshall
Does the ASA have a route for the 10.1.1.0/24 subnet ?
Note also you should probably have a route on the ASA for 192.168.1.0/24 as well.
You can use statics on the ASA or run OSPF.
Jon
Thanks Jon,
I added the following static route on the ASA:
route outside 0.0.0.0 0.0.0.0 66.X.X.X 1 <--- ISP Gateway address
But I still get the same results, can ping from router A but can't from Router B
Added the individual routes on the ASA:
route outside 10.1.1.0 255.255.255.0 66.x.x.x 1
route outside 192.168.1.0 255.255.255.0 66.x.x.x 1
But still no luck.
Thanks.
Jon
Hi John,
After adding the internal network:
route inside 10.1.1.0 255.255.255.0 X.X.X.X
All is working good.
Thanks a lot!
fuadtelfah
believe me my friend you need an access list to permits internal networks to reach outside network. thats all
