InterVlan Issue
son ray
Community Member
hi,
I am new and trying to make inter-VLAN routing on the router. the router is connected VLAN multilayer  PC connected with a switch. I have created VLAN 10 and 20 on the packet tracer. but unable to communicate VLAN with each other VLAN.
some one please help me.
Jitendra Kumar
you need to do the below config on the router. if you are doing an intervlan on the router. don't forget to make a Switch port trunk.
Router>enable
Router#config terminal
Router(config)#int fa0/0
Router(config-if)#no shutdown
Router(config-if)#int fa0/0.10
Router(config-subif)#encapsulation dot1q 10
Router(config-subif)#ip add 192.168.1.1 255.255.255.0
Router(config-subif)#int fa0/0.20
Router(config-subif)#encapsulation dot1q 20
Router(config-subif)#ip add 192.168.2.1 255.255.255.0
Jitendra
Jitendra
 Please, attach the Packetracer  file here. You need to zip it first.
Jitendra Kumar
Router>enable
Jitendra
Jitendra
let me check this.
thanks for the revert..
wow!!! thanks, @Jitendra Kumar it works for me.
