Intervlan not working
HenryGorsten
Community Member
Hi everyone,
Firstly, please go easy, I'm new to networking (started yesterday) and my brain is absolutely fried today, so I may just be making a very simple mistake that someone might be kind enough to point out.
Basically, I created a network earlier that I was happy with, got most things working except my VLANS were not talking to each other. To try and troubleshoot this issue I've created a new network to replicate this issue with a very simple network (1 router, 1 switch, 2 pcs, 2 vlans) and I still cannot ping across vlans, I'm probably missing something very simple so would really appreciate someone pointing it out. I can't seem to attach PKT file so here is an image of my network:
Router config:
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface FastEthernet1/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 no ip address
 clock rate 2000000
 shutdown
interface Serial3/0
 no ip address
 clock rate 2000000
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Switch Config:
version 12.1
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
 switchport mode trunk
interface FastEthernet1/1
 switchport access vlan 10
 switchport mode access
interface FastEthernet2/1
 switchport access vlan 20
interface FastEthernet3/1
interface FastEthernet4/1
interface FastEthernet5/1
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 mac-address 0003.e429.e901
interface Vlan20
 mac-address 0003.e429.e902
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Assigned static IP's to both machines to keep simple, pc6 ip = 192.168.10.3, gateway = 192.168.10.1 & pc5 ip = 192.168.20.3, gateway 192.168.20.1. These machines cannot ping each other, please help.
As I say, please ignore my very, very simple network it's just for replication purposes 🙂
remove the VLAN interfaces from your switch:
no interface Vlan10
no interface Vlan20
HenryGorsten
Community Member
Ignore link lights - they are green, it's just I started up the file and took picture before the link lights turned to green 🙂
no interface Vlan10
no interface Vlan20
Problem solved! Thanks so much!
It was the same issue on my more complex network, can't believe I've been spending time banging my head trying to figure it out when it's so simple.
Really appreciate your help!
with your router-on-a-stick configuration (that's what it is called when you use a trunk between a router and a switch, and subinterfaces on the router), all routing is indeed done on the router. The VLAN interfaces on the switch are not necessary, and in your case actually prevent the inter-VLAN routing.
