12-27-2021 12:51 PM
I have already configured default gateways and still I cannot ping in between the vlans please help.
I will attach the file I worked on, I zipped the pkt file so it would upload.
Thanks for your help
12-27-2021 02:04 PM
what instructions are you following ? Post these instructions. The network as it is right now will not work, you have identical networks at the top and the bottom.
12-27-2021 03:26 PM - edited 12-27-2021 11:34 PM
12-27-2021 03:42 PM
Hello
@Georg Pauwen wrote:
and change the default gateways on the routers (hosts),
Why would you need to do this when HSRP vip is active which the rtrs originally pointed to in the first place?
12-27-2021 11:44 PM
@paul driver Not sure where anything HSRP related comes from, there is no HSRP in the original file (at least not the one I am looking at), and OP does not mention HSRP (and I did not see any instructions, that is why I asked what he, or she, wants o accomplish).
The bottom right in the original file had 'ip routing' enabled without any routing (static or dynamic).
Simply changing the IP addresses of the SVIs (since they are duplicate) and making sure the hosts (routers) point their default gateways makes for end to end reachability.
12-28-2021 12:16 AM
Hello
Understand but In your file you also includes hsrp?, So wouldnt it be easier to NOT to change the hosts D/G's and use the HSRP vip as in theory the hosts could be numorous , Also it adds some resilency if not that much..
12-28-2021 12:26 AM
@paul driver I guess we'll have to wait for an update from OP on what the actual requirements are...
12-28-2021 02:13 AM
Honestly I am new at this and dont understand what is hsrp?
12-28-2021 03:32 AM
there are different ways to approach this. It all depends on what you want to accomplish. You could also just make one of the layer 3 switches a routing device (ip routing enabled) and leave the other one as a layer 2 switch, so all routing would be done on just one switch.
Where did you get this topology from ?
12-28-2021 03:36 AM
I am just beginning to learn VLanning and saw it on a video, my main objective was to complete the task as I saw the instructor do, obviously this is not close to a real life scenario. It just gave me a basic understanding of VLAN's and default gateway etc.
12-28-2021 02:13 AM
Thank you I will check it out
12-28-2021 03:26 AM
Thank you for taking the time out to help me, unfortunately the file you sent is not compatible with my version of packet tracer, my version is 8.0.1.0064. what is your version?
12-28-2021 04:26 AM
I am using the latest version (8.1), send me a private message with your email address.
Do you have a link to that video you were watching ?
12-27-2021 03:08 PM
Hello
You had duplicate L3 vlan addressing. please review the working example.
12-28-2021 11:24 AM
follow
