Devices takes too long to get IP address from Switch
ODAT1
I have Cisco Catalyst C9500-16X switch running ios version 16.12.4. as my core switch. I have configure dhcp on the switch for one of my vlans. initially, all devices were getting IP address from my dhcp server which sits in a different LAN but it was taking them too long for the devices to get an IP address. Now I have dhcp configure on the switch for one of my vlans and devices connecting to this vlan are still taking too long to get IP address. Can I get help resolving this issue?
ODAT1
Hello you'll, thank you for all the great support provided. I was finally able to identify the issue and resolve it. After a debug, I found out the when I ping a host IP address, the reply will redirect to another hop. I remove ip redirect on the svi and the issue was fixed.
Command used
no ip redirect
Thank you all.
10 Replies 10
balaji.bandi
how is your access port config look like
add below line and check
spanning-tree portfast
 ( show run help here if the still issue)
BB
@bb, yes I do have that configured on all my access ports
can you post the configuration, - i have tested with Cat 9300 simple config, client get straight away IP address with out any delay.
look troubleshooting :
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/27470-100.html
BB
try and disable/enable the 'service dhcp':
9500(config)#no service dhcp
9500(config)#service dhcp
@george, okay I will try that and let you know the outcome. Thank you!
can you check the CPU for storm broadcast.
Thanks @ MHM, was helpful.
Hello
As a test trying disabling ip dhcp conflict logging
conf t
no ip dhcp conflict logging
clear ip dhcp
exit
clear ip dhcp conflict *
Kind Regards
Paul
Thanks Paul, this was very helpful.
ODAT1
Command used
no ip redirect
Thank you all.
