intervlan routing multilayer switch C3750
eezergeezer
Hello Guys,
I have a router >>>connected to a c3750 >>> connected to a customer switch..
Router ip Gi01 : 172.31.102.6/24
c3750
port Gi01= vlan 70 svi: 172.31.102.7/24
port Gi06= vlan 72 svi:  10.1.155.33/28
customer switch (cisco unknown device)
port GiX =vlan XX svi: 10.1.155.34/28
I have the following routes:
Router:
ip route 10.1.155.32/28 via 172.31.102.7
switch:
ip route 10.1.155.32/28 via vlan 72
I can ping the customer 10.1.155.34 ip from the switch.
I cannot ping the 10.1.155.34 from the router..
What am i missing here? Would I need to create a sub int on the router to reach the customer 10.1.155.34 address?
trace route 10.1.155.34
Tracing the route to 10.1.155.34
  1 172.31.102.7 0 msec 0 msec 4 msec
  2  *  *  *
  3  *  *  *
Please help .. Am I doing something totally wrong here?
thanks in advance...
Alvaro Garcia
It seems that your customer's switch is getting a ping request witha  source address of 172.31.102.6 but it doesnt know how to reach 172.31.102.6....
so I would say that you need to make sure that the customer's switch has a route (static or dinamic) pointing to your 3750 switch, or configure the deafult gateway of your customer's switch to point to 10.1.155.33...
You dont need this on the 3750 switch:
This because it is already on the routing trable because it is a directly connected route.
mrdogantr
    Did you have activate ip routing on c3750sw with "ip routing" command.
hth
Muammer
Yes, ip routing is enabled.
no aaa new-model
switch 1 provision ws-c3750g-12s
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing             <<<<<<<<<<<<<<<<<<<<--------
no ip domain-lookup
I should be able to route between vlans...
bit more info
If i ping directly from the switch:
ping 10.1.155.34  all is ok
if i extended ping using the source as 172.31.102.7 i cannot ping..
Alvaro Garcia
Thanks Guys,
The problem was a missing route at the customer end. I always second guess myself before pushing to the customer. Just needed some verification from the gurus here!
