InterVLAN routing not working on 3550 switch
dbuckley77
I am trying to setup intervlan routing with 2 vlans on a 3550 switch.
I have done the standard commands:
enabled ip routing
setup vlan interfaces w/ ip add & netmasks
made sure all end devices have the right IP, netmask and gateway pointing to vlan interface IP addresses
checked to make sure switchports are assisned to the right vlans and the devices are plugged into the right ports to match vlan/subnet
Here is my issue:
I have two subnets/vlans
vlan 3 = 10.3.0.0/16  vlan 1 int = 10.3.1.1
vlan 10 = 10.1.10.0/24 lan 10 int = 10.1.10.1
When I am on an end device int he vlan 10 10.1.10.0/24 network I can ping other end users on local vlan but cannot ping gateway of vlan 3 or beyond.
When I am on an end device on vlan 3 10.3.0.0/16 network I can ping other end users on same vlan and I can  ping gateway for vlan 10 but I cannot ping end users on vlan 10.
I have copied the config below and would appreciate any assistance.  Thanks
Building configuration...
Current configuration : 2291 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname CapeNet_Switch
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 3
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan3
ip address 10.3.1.1 255.255.0.0
interface Vlan10
ip address 10.1.10.1 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
20 Replies 20
Reza Sharifi
Are the vlan interface in up and up mode?
sh ip int bri vlan 3
sh ip int bri vlan 10
sh ip int bri fa10
sh ip int bri fa3
What is the output of sh vlan id 3 and
sh vlan is 10
mvsheik123
Level 7
Level 7
May be a typo while posting, bu can you check on Vla10 information?
Your posting says..
vlan 10 = 10.1.10.0/25 lan 10 int = 10.1.10.1
Config:
interface Vlan10
ip address 10.1.10.1 255.255.255.0  --> /24
Thx
MS
It was a typo on the netmask, should have been 24.  I corrected.
All interfaces are up.
sh vlan id output is below
CapeNet_Switch>  sh vlan id 3
VLAN Name                             Status    Ports
3    VLAN0003                         active    Fa0/3, Fa0/12
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
3    enet  100003     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
CapeNet_Switch>sh vlan id 10
10   VLAN0010                         active    Fa0/10
10   enet  100010     1500  -      -      -        -    -        0      0
What is the default gateway for devices on vlan 3 ?
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
When you are able to ping inside the subnet but not outside the subnet. Check whether the PC is configured with correct Gateway IP .
All the Hosts under vlan3 the gateway ip should be 10.3.1.1
All the Hosts under vlan10 the gateway ip should be 10.1.10.1
Example:
PC1
ip address: 10.3.1.10
subnet mask: 255.255.255.0
Gateway ip: 10.3.1.1
If it helps you, please rate the post.
Srikanth
As I stated in my original post.  The ip address, netmask and gateway on the end user devices on both vlans is one of the first things i checked.
All devices on vlan 3 have netmask of /16 and dg of 10.3.1.1
All devices on vlan 10 have netmask of /24 and dg of 10.1.10.1
Thansk guys
barweiss45
Have you double checked that the host device on vlan 10 has the correct defeault gateway?
When I am on an end device on vlan 3 10.3.0.0/16 network I can ping other end users on same vlan and I can ping gateway for vlan 10 but I cannot ping end users on vlan3 (I assume you mean vlan 10 right?)
If this is the case that that takes me back to my point above. When the packet from vlan comes over with the IP address that is outside the VLAN 10 network, the device doesn't have a working default gateway to send it back. The reason why you can ping the SVI for VLAN 10 from vlan 3 is because they are directly connected ( you can see this by doing a show ip route 10.3.0.0 or show ip route 10.1.10.0). However your end devices in vlan 10 have no clue how to leav vlan 10.
Yes barweiss that was a typo.  I meant to say
Sorry for the mistake.
I have triple checked the IP addresses, subnet masks and default gateways configured on the end devices on both vlans.  they are correct.  I have also checked the port assisgnments on the 3550 and cabling to make sure I don't have a layer 1 issue of an end device being plugged into a port that has the wrong vlan assigned to it.
Configuring intervlan routing with two vlans on alayer 3 switch is pretty straightforward.  That is why I am so perplexed.
Sorry just saw you last post that you verified your DG on the hosts. In that case I'm not sure what it could be, because everythig else looks right to me. Can ping the hosts on vlan 10 by soruce it from vlan 3 on the switch?
i.e. ping 10.1.10.x source 10.3.1.1
howithink
this is my configuration for my 3560 layer 3 with intervlan and i am able to ping and send packets between 2 vlans on two different switches. maybe you'll find something in here.
hostname Switch
ip routing
switchport mode trunk
switchport access vlan 20
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.10.10.1 255.255.255.0
interface Vlan20
ip address 10.10.20.1 255.255.255.0
ip classless
Switch#
Hello
Have you created the vlans in the L2 database?
conf t
vlan3,10
exit
also on the trunk interfaces,
default int fa0/1
default int fa0/2
int ran    fa0/1 -2
switchport trunk enacp dot
no shut
ip subnet-zero
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Robert R
What replies do you get from the pings?
Destination host unreachable or request timed out?
can you post the output from the various ping scenarios?
also what's show ip route look like?
If the above is the config of the switch where L3 vlan's 10 & 20 created.
Are the Hosts connected to Fa0/1 and Fa0/2. if so do configure the ports as access ports as like below
If the ports Fa0/1 and 0/2 is connected with the other switches, configure them as trunk port with the specific vlans you want to allow on that trunk port.
switchport trunk allowed vlan 10
switchport trunk allowed vlan 20
Provide me the below output from the switch.
sh interface vlan 10
sh interface vlan 20
sh interface fastethernet0/1
sh interface fastethernet0/2
Srikanth
There are no other switches connected to the 3550.  The setup conists of a single 3550 switch with two vlans on it and two host devices on each vlan.  That's it.  There is no need to trunk any interfaces.
Currently I can ping from host device to another host device on same subnet.  I can ping from host device on either vlan to both defalt gateways.  What I cannot due is ping from a host device on one vlan to a host device on the other vlan.  I have quadrupled checked the ip settings (ip, netmask and dg) on all host dvices and they are set correctly.
I have ip routing enabled.
If I run show ip route both networks are in the routing table.
Firewallsare not the issue nor Av or anything like that.
When I try to ping from a host device on one vlan to a host device on the other vlan I see "request timed out."
The only other thing that is odd is that when I setup continuous pings I see latecny jumping up and down and packets being dropped when I ping from host on vlan 3 to vlan 10 gateway.  But there are no errors on the interface in the switch that the host I am pinging from is using.
