Intervlan switching on a layer 3 switch, not working no other issues in formans match
cindymcgeever
                   Hello.  I have never configured a catalyst 3560 for inter VLAN switching and I am on a project with no support, this may be very basic for some.    The issue I am having is ONE I am not even sure if I am doing this correctly so I do not know where the problem is
The project is to take 5 existing stub networks with semi dumb switches ( not cisco ) hook them all up to a managed switch and on this switch there will be a server that all past stub networks will need to access for backups.   I was using a router but the flash port died, not the card, the port, so now I am stuck doing what I can with the layer three switch.  In the end I will need the server to be able to access the internet as well for RDP sessions.
The switch is plugged into another switch where the config is unknown so if I can somehow get the uplink interface to be DHCP, that would be great.
I was able to ping each VLAN and devices behind the VLANs with the server running Windows 2008 as long as I was on the VLAN of the devices ONLY, otherwise I could not talk to the deivces.    I added multiple IP's and gateways to the server and this did not work.
One subnet did not even have a gateway so I am using Proxy ARP.
Power inline never had to be activated because the ports were bouncing due to it being on.
Please help..
IOS
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"
CONFIG:
enable password cisco
username cisco password 0 cisco
no aaa new-model
system mtu routing 1500
vtp domain cisco
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
spanning-tree logging
spanning-tree portfast bpdufilter default
vlan internal allocation policy ascending
vlan 31
name PLC31
vlan 32
name PLC32
vlan 74
name PLC74
vlan 100
name-Server
interface FastEthernet0/1
power inline never
switchport access vlan 31
switchport mode dot1q-tunnel
interface FastEthernet0/2
description PLC Port VLAN 74
power inline never
switchport access vlan 74
interface FastEthernet0/3
description PLC port VLAN 74
power inline never
interface FastEthernet0/4
power inline never
interface FastEthernet0/5
description PLC port VLAN 32
power inline never
switchport access vlan 32
interface FastEthernet0/6
power inline never
shutdown
interface FastEthernet0/7
power inline never
shutdown
interface FastEthernet0/8
power inline never
SERVER VLAN
switchport access vlan 100
interface GigabitEthernet0/1
description -=Server=-
switchport mode trunk
interface Vlan1
no ip address
interface Vlan31
ip address 192.168.31.0 255.255.240.0
interface Vlan32
ip address 192.168.32.254 255.255.255.0
interface Vlan74
ip address 172.29.75.158 255.255.255.0
interface Vlan100
ip address 192.168.254.254 255.255.255.0
ip default-gateway 172.19.75.1   ??????????
ip classless
ip route 0.0.0.0 0.0.0.0 0.0.0.0
no ip http server ??????????????
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
5 Replies 5
gdeangelis
Not knowing the configuration on the dumb switch, I'd try removing the dot1q statement or if the dumb switches can handle trunking, change the port to trunk.
The original post mentions 5 stub networks. But the config has only 4 networks of which one seems to be the network for the server. So what about the other 2 networks?
Also the original post talks about semi dumb switches. Would I be correct in assuming that each of those switches had one (and only one) of these networks? If so then connecting each of those switches to a port in the 3560 which was in a separate VLAN would be the easy way to identify and access the stub networks.
I am not clear from the config where the server is connected. Is it on Fast0/8 or is it on Gig0/1? And is the server really doing dot1Q trunking?
This config has 3 VLANs configured for what appear to be user VLANs. Assuming that the hosts on these VLANs are configured with IP addresses and masks that are consistent with what is configured on the switch, and assuming that the hosts configured default gateway is the address configured on the switch VLAN interface then I would think that routing between the VLANs should be working.
There is an ip default-gateway configured. But with ip routing enabled the switch will not use this. It is not necessary to remove it, but be aware that it will not be used.
There is a sort of default route configured but it is not configured correctly.
The last 0.0.0.0 should be the address of the next hop device that will get to outside. We do not know enough about the network environment to know what that should be at this point.
Rick
Rick
You might be on to something with the server trunk. If if is on gig1 and that is configured as a trunk that would explain it all. Routing could be working just fine but if the server is where they are trying to ping from it makes sense why it isn't working correctly. The server port should be an access port
The server is on port 8 which is set to VLAN100
The reason you only see 3 networks is because 2 of them have different IP ranges so I was able to seperate them onto a VLAN, when discovering the other three networks they want seperated, I found that they all have the exact same gateway and IP range.  Behind the switches are several different devices doing something different and they all come to a dumb switch running VLAN 1 and the three networks have the same gateway which is listed in the VLAN interface.. each network is connected to a switch which now connects to my switch. I was able to make that VLAN with the shared gateway and I could ping each device....
getting them seperated is a whole other beast and my router crashed and it will not be possible because the Switch I have cannot do NAT, so for now I am making all ports for the networks that use the same gateway, on the same VLAN.  There are no duplicate IP's..
Also, I just added the dot1q trunking as a test to see if this would work...  I also have had the switches port as trunking and access... sigh...
Oh and Rick your very last comment will help a lot! Thank you.
