IOS 15: ¿How do I activate Built-in Licenses for Emergencies?
rogelioalvez
Hello team:
I have a brand new one 3845 in which I need the IP SLA commands available as soon as possible.
¿How can I activate the so-called Built-in Licenses for Emergencies feature? I can not see which IOS commands I have to enter in order to
execute this temporary feature upgrade.
Any help will be greatly appreciated.
Regards, Rogelio Alvez
Reza Sharifi
Hi Rogelio,
You can get a 60 day license for free.  If you need a permanent license, then you need to talk to your sales rep and buy permanent license too enable the features on your device.
have a look at the link below for temp license
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
Reza Sharifi
Hi Rogelio,
Hi Reza:
Thank you very much for your kind answer.
The page you referred me to does not include the chance to get a temp license for 38xx platforms. ¿Do you know of any other page like this for routers like mine?
TIA, Rogelio
Hi Rogelio,
You need a CCO account to login and input the data.
  Make sure you do get the license and put the key in , i believe after 60 days  if the box reloads those features will disappear if you don't.  Not a big fan of this new licensing model.  Lot more stuff you need to keep track of specially if you can't use the license manager .
