IOS command to suppress output
matt.millington
Is there a command to suppress output warnings in IOS? I am trying to use Cisco Prime to configure a template to deploy to all my switches so that they will all have a standard configuration, but when I apply:
spanning-tree portfast default
I get the warning about applying portfast to ports connected to other switches, etc. This breaks the script and it doesn't apply any more commands in the template after this warning. Is there any way to turn off this output/warning?
-Matt
Leo Laohoo
Put an extra CR below the command.
Unfortunately, it still happens even with a couple CRs after the line. Is there any way to suppress that output?
