Ios Compression
illusion_rox
Level 7
Level 7
Hi, i am looking for a way to do software data compression through cisco IOS. while searching i went through a white paper that discussed different compression techniques like per-interface compression, tcp/ip header comp etc, but i am not able to find any configuration for data compression through software, so is it possible to do so, kindly keep these facts in mind
1) i am not using VoiP i just want to compress my data payload
2) most of the routers are 1841, but we also have 2811, 3845, 3640
So is there any way to do software compression ??
thanks
Hieu Cao
Level 7
Level 7
Take a look at this link - it may be what you're looking for.
http://www.cisco.com/en/US/tech/tk713/tk802/tsd_technology_support_protocol_home.html
HTH,
hieu
Joseph W. Doherty
Take note without compression hardware, compression can consume a large percentage of CPU.
hi, i have seen the link but it has shown example of on mppc, we are using DSL mostly in our network and ppp is not there, so far what i have learned that cisco supports
stacker, predictor and mppc, but i havent found configuration for predictor so if any1 can help me out ?
