IOS file help for web based services
paul dungey
Level 3
Level 3
I would like to check the following IOS bin files to see if they contain webbased services does cisco have a facility??
I need to be able to access each switch via the web interface i've set each switch with a static IP and configured username amd password for Level
15 access, saved configuration this is my question is web based services enabled on the IOS version below.
c2950-i6k2l2q4-mz.121-22.EA12.bin
c3750-ipbase-mz.122-35.SE5.bin
c2960-lanbasek9-mz.122-53.SE2.bin
Paul
Mark Malone
they all support HTTP access for we gui if required , the K9 image on 2960 should support HTTPS too
Not every image  is on it but you can check these things in the Cisco feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
