IOS for VSS
Ibrahim Jamil
Level 6
Level 6
Hi Experts
What IOS do i need according the below output in order to run VSS,if it doesnt support,Please Mention to me the sup 720-10gb that fits inside my Chassis
2)any Module for FiberChannel fits in the 6509-E for the SAN
Please Examine the Below output from my 6509-E,
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 17-May-07 00:41 by kellythw
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
uptime is 1 year, 48 weeks, 6 days, 7 hours, 30 minutes
Time since  switched to active is 1 year, 48 weeks, 6 days, 7 hours, 30 minutes
System returned to ROM by reload (SP by reload)
System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF9.bin"
cisco WS-C6509-E (R7000) processor (revision 1.3) with 491520K/32768K bytes of memory.
Processor board ID SMC11210020
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
20 Virtual Ethernet/IEEE 802.3 interfaces
74 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
6 Replies 6
IAN WHITMORE
Level 4
Level 4
Have you not got a Cisco login? You can use their software advisor. That will tell you exactly what you need.
Also you could issu  a #show module and post that information.
Ian
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAD092601HG
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL09337K80
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL09169ETP
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL09285AYR
Mod Sub-Module                  Model              Serial        Hw     Status
  1 Centralized Forwarding Card WS-F6700-CFC       SAD09780BRK   2.0    Ok
  2 Centralized Forwarding Card WS-F6700-CFC       SAD073106PK   2.0    Ok
  3 Centralized Forwarding Card WS-F6700-CFC       SAL07148SZC   2.1    Ok
  5 Policy Feature Card 3       WS-F6K-PFC3B       SAL07285APT   2.1    Ok
  5 MSFC3 Daughterboard         WS-SUP720          SAL0928588W   2.3    Ok
From what I can see for a 6509-e with sup720-10g the latest IOS is:
12.2.33SXI5(ED) so it's not a GD.
This is for the virtual switching supervidor engine 720 with 10ge uplinks.
i.e. if you want VSS you need to upgrade the supervisor. I mean it's not really an IOS thing. To use VSS you need the right card to begin with.
OR iin other words updating your current IOS won't make is VSS compatible. You need the new (and expensive) supervisor. Talk with your Cisco dealer cos they sometimes do 'buy-back' so you can get it cheaper.
You can see that your card doesn't suppoer VSS here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856.html
Hope that is the information you wanted.
Ian
What the GD Means
ED = Early deployment i.e. it could still have some bugs or as Cisco like to call it now 'caveats'.
GD = General Deployment i.e. it 'should' be a bug free release.
Ian
If I helped, please rate me.
Thank you I ve rated all ur Reply
