06-12-2013
03:34 PM
- last edited on
03-25-2019
04:25 PM
by
ciscomoderator
hi guys
i am having issue with new IOS i am trying to upload.
I have two stack switch running with c3750-ipservicesk9-mz.122-37.SE and trying upload new IOS c3750-ipservicesk9-mz.122-55.SE5.bin.
both switch does not have enough Flash to store both IOS so i have delete 122.37 and upload 122.55 from tftp. after reloading both switch i am getting below error.
Now both switch is rebotting after this message; i guess this new IOS is valid for this model.
anyone please let me know if they have come across with same problem and possible solution.
06-12-2013 04:01 PM
Try loading 12.2(55)SE7.
06-12-2013 04:11 PM
i cant as this is what customer has proposed to us to implement on their enviornment.
06-12-2013 04:14 PM
LOL.
Remind the client that they can't implement something that won't work.
06-12-2013 04:22 PM
they won't accept this; as another stack running same IOS....
06-12-2013 04:24 PM
Ok then. Post the output to the following commands:
1. sh version;
2. sh switch detail;
3. sh license; and
4. sh inventory
06-12-2013 04:26 PM
current IOS won't boot up system i have to do Xmodem to install OLD IOS and then i can grab the info
06-12-2013 07:53 PM
Kindly give it a try and update us the result.We will help in case it doesnt help for you.
Inayath
06-12-2013 10:33 PM
so now i have upload old device to only one switch as it took long time with xmodem
here's the info as asked
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(37)SE, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 10-May-07 16:31 by antonino
Image text-base: 0x00003000, data-base: 0x01440000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
Switch uptime is 2 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-37.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C3750G-12S (PowerPC405) processor (revision Z0) with 118784K/12280K byt
es of memory.
Processor board ID FDO1504X19L
Last reset from power-on
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 44:E4:D9:1C:ED:80
Motherboard assembly number : 73-9678-14
Power supply part number : 341-0048-03
Motherboard serial number : FDO15040VJG
Power supply serial number : DTN1501310Z
Model revision number : Z0
Motherboard revision number : A0
Model number : WS-C3750G-12S-E
System serial number : FDO1504X19L
Top Assembly Part Number : 800-26634-12
Top Assembly Revision Number : C0
Version ID : V14
CLEI Code Number : COMA410BRA
Hardware Board Revision Number : 0x06
Switch Ports Model SW Version SW Image
* 2 12 WS-C3750G-12S 12.2(37)SE C3750-IPSERVICESK9-M
Configuration register is 0xF
Switch#sh switch detail
Switch/Stack Mac Address : 44e4.d91c.ed80
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 0 Provisioned
*2 Master 44e4.d91c.ed80 15 0 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
2 Down Down None None
Switch#
Switch#sh license all switch 2
% License not supported on this device
Switch#sh inven
Switch#sh inventory
NAME: "2", DESCR: "WS-C3750G-12S"
PID: WS-C3750G-12S-E , VID: V14, SN: F***1504X19L
NAME: "GigabitEthernet2/0/1", DESCR: "10/100/1000BaseTX SFP"
PID: , VID: , SN: *************
06-12-2013 10:39 PM
4+ hours if you use default XModem speed (9600) or 45+ minutes if you change the baud settings.
Fairly new 3750G-12S (January 2011). So you say you couldn't upgrade the IOS?
Maybe your IOS image is corrupted. Can you post the process whereby you are upgrading it?
06-12-2013 10:40 PM
I have no idea whatsoever why people keep covering part of their serial numbers. All I can say is the bits you've covered, two characters, ain't the important parts. It's the LAST FOUR characters.
First three characters is the factory that made the appliance. The last four bits is your ORIGINAL serial number.
06-12-2013 10:44 PM
thats good point about SN
anyways dont know how this switch has 122.37 at first stage...
my steps are:
Delete current IOS from both flash (to make more room)
Upload New IOS from tftp
Verify MD5 for both flash
change boot veriable
and Reload
06-12-2013 10:49 PM
Nope.
1. Download the IOS file (TAR file) from Cisco;
2. Check the MD5 hash;
3. Use the command "archive download-sw /dest 1 /dest x tftp://
[OPTIONAL] Verify the MD5 of the BIN file; and
4. Reload.
06-12-2013 10:53 PM
OK will try that but what's wrong with the option i am doing it?
06-12-2013 11:00 PM
You have MD5 verify AFTER you've downloaded. If your MD5 hash don't match this means you've got to do the entire process all over again.
Plus, the "archive" command can delete your old IOS and change the boot string for you.
