IOS K9 Crypto for 2950 Switches
Remo.Hehlert1
Hi together,
we have several 2950 Switches and wont to upgrade them to newer FW with K9 crypto.
The only IOS what I have found is version c2950-i6k2l2q4-mz.121-20.EA2.bin but this one seems to have problem with Network traffic.
So my qestion is, is there a other FW what I can use for our switches?
thanks a lot and have a nive weekend!
Remo
I usually google the image file name - found this for example:
http://best-practice.se/dump/c2950-i6k2l2q4-mz.121-22.EA14.bin
7 Replies 7
Reza Sharifi
The 2950 series switches have been EOL and EOS for a few years now. So, you may not be able to find newer versions of IOS for it. I only see 2955 in the download list and not 2950.
Thank you all,
I have seen that the latest version shoud be 12.1(22)EA10 but I can't find any (offical) download sites.
So if no one can provide the image I will have a look at c2950-i6k2l2q4-mz.121-20.EA2.bin Image cause it seems this one has the only problem with the community string longer than 129 char, if i read it right :-)
Thanks for your help
tbc
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(20)EA2, RELEASE SOFTWARE(fc1)
Compiled Wed 19-May-04 03:07 by antonino
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA10, RELEASE SOFTWARE (fc2)
Compiled Tue 08-May-07 11:50 by myl
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)
Compiled Tue 26-Oct-10 10:35 by nburra
A lot of years in between...
Indeed there are several more version but no one can be downloaded or can you provide me a link for downloading?
thank's
TBC
Thank's a lot for helping!
Iulian Vaideanu
Level 4
Level 4
Latest K9 (well, K2) IOS for C2950 was c2950-i6k2l2q4-mz.121-22.EA14.bin - googling it should provide some download links (unofficial, of course - md5 sum should be 8d3250ee253b81b7fe2762e281773fbc).
