IOS question
wxpsaint98
Community Member
If use IOS 12.2(25)SEE 4 on catalyst switch 3560G or catalyst switch 3560 or
catalyst switch 3500 series XL , is it all the configuration command can work on these 3 switch?
ganeshhiyer
Community Member
It will work with 3560G & 3560, but it is not supported by 3500 XL series.
Kindly rate if the suggestion helps u out.
Ganesh.H
glen.grant
No a 3560 is a l2/3 switch . The ancient 3500xl series is a layer 2 switch only so the commands are not the same . Some will be the same but there are a lot more available functions on the 3560 versus the 3500xl.
