IOS upgrade 6509-E with sup32
keven.baker
                   I have a 6509E with supervisor32 modules  currently running
3223-ipservicesk9_wan-mz.122-33.SXI5.bin
Went to the Cisco Feature Navigation and believe I can go to
3223-ipservicesk9_wan-mz.122-33.SXI12.bin
Was wondering if I am correct?  Is there a better way to find out?
I have attached the "show inventory"
Any help/guidance would be appreciated.
Leo Laohoo
You should be right to go up to SXJ.  Just make sure you have the prescribed DRAM and bootflash size.
Reza Sharifi
Leo is correct.  The latest image for Sup-32 is SXJ6 as long as you have 512 DRAM and 256 flash.
s3223-adventerprise_wan-mz.122-33.SXJ6.bin
http://software.cisco.com/download/release.html?mdfid=280829687&flowid=3318&softwareid=280805680&release=12.2.33-SXJ6&relind=AVAILABLE&rellifecycle=MD&reltype=latest
