IOS upgradiation in 3750 stack model.
sateeshk10
How to upgrade the IOS in 3750 stack conectivity switches
I have 3 swtiches with stack connection. I can telnet to one switch. HOw to upload the IOS in other switches..
config # sh switch
Current
Switch# Role Mac Address Priority State
*1 Master 0012.00cf.6d80 1 Ready
2 Slave 0012.00de.0d00 1 Ready
3 Slave 0012.00cf.7400 1 Ready
pls let me know the procedure..
thanks
Sateesh
kkunzler
Thanks for good url...I need small help and its very urgent
In the document they have mentioned reload switch means..If i give the reload commnad,both the switches are gets rebooted ??? or Invidually i have to reboot the switches??
In my switch its shwoing three switches..When i type sow its showing two flash..How will i know the are my switches runing on stack..
pls find the below the required details
sh switch
Current
sh flash?
flash1: flash:
sh ver
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(19)EA1d, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 05-Apr-04 22:06 by antonino
Image text-base: 0x00003000, data-base: 0x009206D8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
tc-sw-hou-core uptime is 4 weeks, 4 days, 7 hours, 38 minutes
System image file is "flash:c3750-i5-mz.121-19.EA1d/c3750-i5-mz.121-19.EA1d.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision E0) with 118776K/12288K bytes of memory.
Processor board ID CAT0835X156
Last reset from power-on
Bridging software.
2 Virtual Ethernet/IEEE 802.3 interface(s)
72 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:12:00:CF:6D:80
Motherboard assembly number : 73-8046-06
Power supply part number : 341-0048-01
Motherboard serial number : CAT08350H5P
Power supply serial number : LIT0827010Z
Model revision number : E0
Motherboard revision number : A0
Model number : WS-C3750G-24T-E
System serial number : CAT0835X156
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.1(19)EA1d C3750-I5-M
2 24 WS-C3750G-24T 12.1(19)EA1d C3750-I5-M
3 24 WS-C3750G-24T 12.1(19)EA1d C3750-I5-M
Switch 02
Switch Uptime : 4 weeks, 4 days, 7 hours, 37 minutes
Base ethernet MAC Address : 00:12:00:DE:0D:00
Motherboard serial number : CAT08350HB6
Power supply serial number : LIT082700LC
System serial number : CAT0835X184
Switch 03
Base ethernet MAC Address : 00:12:00:CF:74:00
Motherboard serial number : CAT08350H7C
Power supply serial number : LIT08270200
System serial number : CAT0835X15F
Configuration register is 0xF
sateesh
Still i am awaiting for reply..its very urgent..
sateesh
