wrong system software for this hardware
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-18-2008 04:30 PM - edited 03-06-2019 02:01 AM
Hey guys, I have a problem.
I loaded the incorrect IOS image via tftp and in the process erased the flash. Now when i start up I get wrong system software for this hardware and get dropped into rommon> mode.
I read an article on experts in regards to using TFTP commands to re-download the image but the hardware im on (3640 router) doesn't seem to support tftp in rommon mode. See rommon options below.
rommon 1 > ?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis disassemble instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
rommon 2 >
There is also some documentation to use the boot option to load via tftp but no go.
The dnld option looks like it might be my way out but how does that work? i need to download an image via serial? do i make a serial connection with my pc? is it the 15 pin connector on the back of the hardware they are talking about or my wan serial connections?
What about loading ios via pcmcia?
Any help appreciated guys. Thanks in advance.
Mike - Stuck in rommon> mode!!
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-18-2008 11:21 PM
you can download it via consol port using hyperterminal :
just give it a command like: xmodem c3640-i-mz.120-4.T
then go to hypertermial/transfer/send file, choose the file and the protocol (xmodem).
it is a slowly way but it will function (incha allah)
rommon 7 > xmodem c3640-i-mz.120-4.T
Do not start the sending program yet...
File size Checksum File name
4064296 bytes (0x3e0428) 0x6501 c3640-i-mz.120-4.T (bad checksum: 0xaa54)
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c3640-i-mz.120-4.T ...
Erasing flash at 0x307c0000
program flash location 0x303e0000
Download Complete!
program load complete, entry point: 0x80008000, size: 0x3e030c
Self decompressing the image : ################################################
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-19-2008 01:36 PM
If your 3640 has a PCMCIA card in slot0 containing a copy of the IOS you want:
rommon>boot slot0:image-name.bin
Otherwise, do XModem/YModem through the console port, as already suggested.
