ios uploading using xmodem in 3750 switch
shiv
Hi Support,
Shiva here how can i upload new ios in 3750 switch using xmodem ? because i deleated flash of the same switch.
mahmoodmkl
Level 7
Level 7
Thanks alot Mahmood.
Do u know any practical truobleshooting orinted books for ccnp and ccie in routing and switching.If u have pls send the link.
K bye
Take care...........
Shivanand
Giuseppe Larosa
Hello Shiva,
you can use the procedure
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_14_ea1/configuration/guide/swtrbl.html#wp1099467
note: setting the speed to 11500 bps can save hours of download time I did it you need the change the parameters on the device and then on the PC terminal emulator before starting the download.
but if you didn't switch off the switch you can use TFTP to write the image on your flash becuase you still have an IOS running
Hope to help
Giuseppe
