IOS with ssh feature for WS-C3560-48PS
manjit_raulo
Please suggest a IOS with ssh feature for WS-C3560-48PS
Lucien Avramov
Level 10
Level 10
you need a k9 image, either base or ip services will work.
base with crypto: c3560-ipbasek9-mz.122-52.SE.bin
ip services with crypto: c3560-ipservicesk9-mz.122-52.SE.bin
Thanks a lot for the reply.
It would be quite helpful to me if u suggest how to select a IOS for upgradation for the below scenarios.
Currently I have 4 switches to upgrade for ssh feature, below are the existing IOS images.
i.e.
1.c3560-ipbase-mz.122-25.SEB4(Model:WS-C3560-48PS)
2.c2950-i6q4l2-mz.121-14.EA1a.bin(Model:WS-C2950G-24-EI)
3.cbs30x0-lanbase-mz.122-40.SE2(Model:WS-CBS3020-HPQ)
4.c3500xl-c3h2s-mz.120-5.WC10.bin(Model:WS-C3548-XL-EN)
So please suggest the guidelines to select the correct image & which are the important things I have to keep in my mind while selecting the IOS image.
waiting for your reply.
Have you tried to download an image from our website?
It's fairly simple and it speaks for it self: when you select the platform (3560,2950), on the right you see the list of images (usually 4 to 6 names).
Those in the description that say W/O crypto, means without crypto, those are the ones you do NOT want to download.
The other images will work.
Go on the website and see for yourself.
Thanks for yr reply.
Yes, I have tried to download...but there are many types of images available for the same release versions ,such as,
1.Advanced ip services
2.ip services
3.ip base
Also many types are there........
I am little confused,which one choose.
Also,in theh platform drop down list,I am not able to find the platform for WS-C3548-XL-EN.
Could please suggest,which I image to download for cisco 3548 switch with ssh feature.
